radio wiring help...
Old Oct 2, 2005 | 07:02 PM
kingSfit's Avatar
Default radio wiring help...
hey guys i just got a car last week and bam, there was no radio in there, some **** thieves ripped out the deck, but unplugged it where u connect the wires... and i got a new alpine deck but when install it , it doesnt work. if theres any spot i can look at or if some electrical **** got damage or whatever, i would like any help ... driving with music is no biggie but i prefer it thanks
sorry forgot to mention its a 1990 si thanks again
Old Oct 2, 2005 | 11:24 PM
db8xc1x39
Guest
Posts: n/a
Default Re: radio wiring help... (bun.)
so is your harness (the plig) where all you wires meet still in there?? or is it just bare wires with the metal portion of the wire sticking out?? if your harness is still intact and you dont see any bare wires, all you have to do is buy a brand new radio kit harness and match the colors from that stereo harness into the kit harness and your good as new. let me know if anything so i can better understand you goof luck man
theives
Old Oct 3, 2005 | 08:24 AM
db8xc1x39
Guest
Posts: n/a
Default Re: radio wiring help... (db8xc1x39)
pm'd and helped out. gald to see your stuffs working!
Old Oct 3, 2005 | 03:08 PM
db8xc1x39
Guest
Posts: n/a
also if you know anyone that needs alarms remote starts or any electronics such as amps subs decks or navi put in cars for anyone you know refer the business to me man!!! if ANYTHING pm me!! dont reply thanks again and glad i could help!!
Old Oct 18, 2005 | 10:45 AM
gulfboomb's Avatar
hi, db8xc1x39, i have same problem some motherfucking theives stole my car deck the second day I bought it, and also pulled the wiring harness leaving the wires hanging out i don't know what wires are which, I found the diagram, it's different though, I connected the factory wires to the new deck(i bought another one after lost the first one) wires, am i supposed to turn on the new deck just by connecting three wires: 12 volt ignition, 12 volt battery wire and ground wire? I tried but it didn't work, what went wrong?
Old Oct 24, 2005 | 12:47 PM
HondaTechdotcom's Avatar
Default Re: radio wiring help... (gulfboomb)
Did you check your fuses...
Old Oct 24, 2005 | 01:10 PM
Default Re: radio wiring help... (bbun)
Does anyone have a wiring color code or diagram for the stock radio harness?
I searched archives but no luck!
I have a 96 Prelude Si
Thanks!
Old Oct 26, 2005 | 12:54 AM
db8xc1x39
Guest
Posts: n/a
Default Re: radio wiring help... (HondaTechdotcom)
pm man check your ****.
Old Oct 26, 2005 | 07:52 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaTechdotcom &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone have a wiring color code or diagram for the stock radio harness?
Thanks!
</TD></TR></TABLE>All Hondas http://www.installdr.com/Harnesses/HA-Wiring.pdf 94
Old Oct 26, 2005 | 03:02 PM
Rubixcu7's Avatar
check the radio fuse under the hood... 9 times out of 10 if u work on the wiring... it will blow... just my 2 cents
Old Oct 26, 2005 | 04:17 PM
Got PM thanks!
Old Oct 26, 2005 | 04:18 PM
Default Re: radio wiring help... (fcm)
That link really helped!
Thanks!
Old Oct 28, 2005 | 02:15 AM
eastsidecustomz's Avatar
fo sho. take it easy man
nizubster
Audio / Security / Video
Jul 13, 2013 11:49 AM
detuned
Apr 3, 2009 02:34 PM
iENJOIfallen
22
Aug 16, 2008 02:38 PM
usdm.ehtu
Mar 17, 2007 07:54 PM
CivicRider011
Dec 10, 2006 07:07 PM
