radio power problem...
Old Jun 4, 2004 | 10:10 AM
antivic's Avatar
Default radio power problem...
i jsut got a new radio...did the wiring without the harness...evwerything seemed to be wired up right and no p ower...checked the cig lighter and that didn't work...i went to check the fuse and tehre was none...i then put in a fuse and it still didn't work....any ideas? its driving me nuts
Old Jun 4, 2004 | 08:56 PM
flip b18b's Avatar
Default Re: radio power problem... (antivic)
there is also a second fuse related tot he radio it's the back up fuse and it's located under the hood int eh fuse panel, if that dosen't fix things get your self a test light and see what things are doing and what they arn't
Old Jun 5, 2004 | 11:50 AM
antivic's Avatar
Default Re: radio power problem... (flip b18b)
i found the problem..i had the fuse in the wrong location kept blowin a 10 fuse instead of running the 15...but now only 1 speaker works :x
Old Jun 5, 2004 | 08:43 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Thats why you should spend the 17 bucks on an adapter harness. There are even some places online that have them much cheaper.
Old Jun 7, 2004 | 09:44 AM
fcm's Avatar
fcm
Old Fart
The unit is miswired,pull unit and rewire. Check all wires first 12v+conn. 12v+acc. 12v-ground and 4 pr. sp.wires [8] power ant triggerwire[if you have one] light lead [if you need one]. hope this helps 94
Old Jun 7, 2004 | 10:37 AM
From: eating the shit out of pizza in raleigh, NC, USA
Default Re: radio power problem... (fcm)
hardwiring into the stock harness is not a good idea, i hope you didnt cut the factory harness completely off, if you havent, i'd advise getting a harness for 16 bucks
Old Jun 7, 2004 | 10:44 AM
john666's Avatar
Default Re: radio power problem... (2ndchancehonda)
i think it was like 8 dollars at walmart. i could b wrong tho.
AnonymousSquid
Audio / Security / Video
Jan 10, 2008 07:51 PM
AcInTheEg
May 2, 2007 04:05 AM
ef9_pr0jekt
Aug 11, 2006 04:07 AM
ScottieA
Jan 23, 2006 12:01 PM
2LoW4FaThOeS
Oct 1, 2005 05:13 PM
