Radio looses memory
Old Jul 28, 2005 | 11:34 AM
skrewdriver88's Avatar
Default Radio looses memory
Well i blew a radio fuse (7.5 Amps) under my hood so after i replaced it the HU (Panasonic CQ-C5310U) doesn't hold the memory or anything. When ever i start the car the head unit will reset and go through the test all over again. I have checked the fuse under the dash and behind the radio and those are all ok. So im guessing that it is something wrong with the constant power source under the fuse box where it is connected. Any other suggestions?
TIA
Old Jul 28, 2005 | 12:06 PM
fcm's Avatar
fcm
Old Fart
Default Re: Radio looses memory (skrewdriver88)
Pull the HU and check for constant power on the Panasonics yellow wire, at the plug going into the HU, if there is power there the problem is in the HU, if there is no power there, recheck the 7.5A fuse that you replaced, make sure it was not DOA.
Normally for today's HUs the 7.5A fused constant power is not enough, if you are using the HUs internal amp.
I would suggest that you run a fused 12ga or 10ga from the batt. to the yellow wire of the HU, [just like you would to an amp], even if it was working before, the HU was not getting all the power it needed, running the power wire from the batt. will improve SQ. 94
Old Jul 28, 2005 | 11:46 PM
Default Re: Radio looses memory (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Pull the HU and check for constant power on the Panasonics yellow wire, at the plug going into the HU, if there is power there the problem is in the HU, if there is no power there, recheck the 7.5A fuse that you replaced, make sure it was not DOA.
I would suggest that you run a fused 12ga or 10ga from the batt. to the yellow wire of the HU, [just like you would to an amp], even if it was working before, the HU was not getting all the power it needed, running the power wire from the batt. will improve SQ. 94</TD></TR></TABLE>
alright thanks i will chech that in the morning.
P.S. thanks for the help on the extra alarm siren using the relay i got it all working and its LOUD as a Mother F*cker
Old Jul 30, 2005 | 07:48 PM
Orpheus1985's Avatar
Aren't there extra spots under the steering wheel for extra const. power, and acc., etc. Could you run a wire from that extra slot to the HU, using, say, a 7.5A fuse?
How much better would that sound over just using the harness?
Old Jul 30, 2005 | 10:41 PM
Turbo(less)DB8's Avatar
Default Re: (Orpheus1985)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Orpheus1985 &raquo;</TD></TR><TR><TD CLASS="quote">Aren't there extra spots under the steering wheel for extra const. power, and acc., etc. Could you run a wire from that extra slot to the HU, using, say, a 7.5A fuse?
How much better would that sound over just using the harness?</TD></TR></TABLE>
Usually there are plenty of constant 12v sources near the fuse box. Test the wires with a digital meter. this is a lot simpler then running a wire thru the firewall. If this doesn't work something might have gotten damaged in ur deck.
Old Jul 31, 2005 | 07:36 AM
fcm's Avatar
fcm
Old Fart
How much better would that sound over just using the harness?</TD></TR></TABLE> There is a 12V+ constant free pin on the fuse box, that you could use, but as anything in the car it is part of the cars electrical system, and although the free pin is not used for anything else in the car, it is on the same main fuse as the rest of the constant power loads in the car, and as the "high power" HUs of today will have at least 10A fuses, [some, like some Alpine have a 20A fuse] on the yellow constant power lead, running a lead directly off the batt. is the best way, it will be a dedicated power lead for the HUs internal amp. 94
Old Jul 31, 2005 | 07:57 AM
Naison's Avatar
yeah, I had this happen to me before. The only reason for youe HU to loose memory and such is if it's not wired to the main (red) and the constant (yellow) correctly. Basically your just turning it on and off without saving. Check to see if your wiring harness is wired to the same colors.
CantThinkofaNam
Dec 3, 2018 02:03 PM
karrar55
Mar 30, 2011 05:08 AM
KING_LIAN
Audio / Security / Video
Feb 3, 2008 04:03 PM
azz_kicker
Aug 19, 2006 10:34 PM
_Cyclone_
Jul 17, 2005 08:06 AM
