Radio Harness
Old Sep 24, 2006 | 09:27 PM
ITR43's Avatar
Default Radio Harness
I have a 2001 Integra with a factory stereo. (type r if it makes any difference at all). What color is the radio antenna wire? I've searched all over the place and am hearing different things.
One thread said it was Yellow/White
Another said Blue/Yellow
Another.. Yellow/Green
Yet another said Brown/White
and according to http://www.installdr.com/Harnesses/HA-Wiring.pdf , there isn't an antenna wire since it's a 2001.
So can someone CONFIRM which wire is the antenna wire? THANKS!!!
Old Sep 25, 2006 | 06:08 AM
94_DC4's Avatar
Default Re: Radio Harness (ITR43)
The Power Antenna is yellow/green.
Old Sep 25, 2006 | 11:16 AM
fcm's Avatar
fcm
Old Fart
What does the oem radio plug look like?... http://www.installdr.com/Harnesses/HA-Wiring.pdf it should be the second one, but I have seen some 99 up tegs still using the first one. 94
Old Sep 26, 2006 | 07:05 PM
incubus's Avatar
Default Re: Radio Harness (fcm)
use an aftermarket harness and it will be blue/white. why are u worried about the factory color are you actually going to hack your factory harness off?
Old Sep 26, 2006 | 09:29 PM
ITR43's Avatar
Default Re: Radio Harness (incubus)
Looks like it's Yellow/Green. I'm installing a switch, so I can lower the antenna down when playing a cd.
Old Sep 27, 2006 | 06:56 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR43 &raquo;</TD></TR><TR><TD CLASS="quote">Looks like it's Yellow/Green. I'm installing a switch, so I can lower the antenna down when playing a cd.</TD></TR></TABLE> Are you using the stock HU? also was it the first, [1986 -1997-98] or the second, [1997 -1998 And Newer] plug of the link I posted, and if the second one, what is in pins E, F, G ? 94
xunkn0vvnx
Audio / Security / Video
Jan 26, 2017 11:57 PM
TheCivicMafia
Sep 1, 2009 07:34 PM
enefin
Dec 17, 2006 10:46 AM
nocturnal EG
16
Nov 3, 2006 08:04 AM
94B18B1Teg
May 11, 2004 05:44 PM
