radio code does not work.
Old 01-31-2008, 03:28 PM
hoang's Avatar
Default radio code does not work.
hey guys, the battery on my dads '03 pilot crapped out, and the radio does not work, i tried pressing in the code multiple times (have the card that came in the owners manual sleeve) any ideas?
Old 01-31-2008, 04:32 PM
fcm
Old Fart
fcm's Avatar
Default Re: radio code does not work. (hoang)
It's the wrong code.
Your not entering it properly.
There is a problem with the code chip.
To confirm proper code, pull the HU so you can get to the serial number, go to your local Honda dealer, [service department] with the car and proof of ownership, explain the code will not work and you need to confirm it is the correct code, it will take them a few sec. to punch it up, they should not charge to do so. 94
Old 02-01-2008, 03:52 AM
i my honda
Global Mod
White Smoke's Avatar
Default Re: radio code does not work. (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">To confirm proper code, pull the HU so you can get to the serial number, go to your local Honda dealer, [service department] with the car and proof of ownership, explain the code will not work and you need to confirm it is the correct code, it will take them a few sec. to punch it up, they should not charge to do so. 94</TD></TR></TABLE>
Old 02-01-2008, 08:18 PM
hoang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">It's the wrong code.
im pretty sure it has something to do with this code chip you speak of, because the battery has been disconnected before and i used the same code, and worked perfectly. guess will have to bring it into the dealership
Old 02-02-2008, 04:46 PM
Frickr's Avatar
if you entee the code wrong the first time you have to wait an hour with the ignitionnon to enter it again
RunsWithBorders
06-12-2018 02:54 PM
michla77
05-26-2008 03:22 PM
micah128
02-20-2007 11:25 AM
killer_Bseries
10
12-16-2006 06:30 AM
crx_ef8
Acura TL, RL & ZDX
10-03-2003 09:03 AM
Quick Reply: radio code does not work.
