Quick Question on fuses
Old Apr 25, 2006 | 01:35 PM
92BluEH-3's Avatar
lulz
Default Quick Question on fuses
ok well heres the deal im running a 920w kenwood 2ch bridged to 2 12" kicker comps (old school round ones) and they are at 8ohms a piece and i have it wired down to 4 ohms and well i was at a car show type deal and i decided to see what my subs can do so i cranked it up and blew my 40 amp fuse on the actual amp not inline. i dont know how i did it cuz thats a big *** fuse. and i really dont wanna worry about blowin fuses so is there anything that i can do to kinda prevent it even though i cant actually stop it from happenin just make the fuses last longer.
Old Apr 25, 2006 | 07:08 PM
sony224422's Avatar
Default Re: Quick Question on fuses (92'BluV-tecHatch)
something isn't wired right.. or the 40 isn't the right size for the amp. Make sure the amp can handle the load.
Old Apr 25, 2006 | 09:28 PM
ccjustin's Avatar
I wouldn't worry about it, 40 isn't that big of a fuse (as far as sub amps go). If you're railing your system like that it just pulled too much for what the amplifier was cool with and popped the fuse. put another one in and don't listen to it that loud.
If you want more power go with a bigger amplifier and bigger power wire. Don't just put a bigger fuse in there, it's 40 because more than 40 amps will probably catch the amplifier on fire
Old Apr 26, 2006 | 06:59 AM
92BluEH-3's Avatar
lulz
Default Re: Quick Question on fuses (ccjustin)
i dont know about catchin on fire its fan cooled but o well and im thinking around going with a 8ga power wire and using an inline fuse. is that good?
Old Apr 26, 2006 | 08:23 AM
Skip01's Avatar
Are they SVC subs?Just wonderin nothin to do with it blowing fuses.
Whats your electrical setup,usually when ur amp blows its fuses it not getting enough amperage?
Old Apr 26, 2006 | 01:14 PM
92BluEH-3's Avatar
lulz
Default Re: Quick Question on fuses (Skip01)
im pretty sure they are single voice coils and its a 12ga power and ground wires. and they are run pretty strange ill see if maby i could snap a pic of where they go to after the battery. no i didnt install that part it was on there when i bought it so i figured it worked so why not. and 12ga speaker wire and its bridged. i think the fuse just blew cuz i had it cranked. i put a 25 in there for a day and i destroyed that later but im getting some more 40's
Old Apr 26, 2006 | 02:28 PM
Skip01's Avatar
When i say electrical i mean,Alternator and Battery and what not.
I would at least go with a 4ga power wire kit.
I personally have a 2ga power wire from front to back.
I use 12ga for my speakers thats about it.
Also is the 12ga power wire fused close to the battery?
Old Apr 27, 2006 | 08:23 AM
fcm's Avatar
fcm
Old Fart
LOL, 12ga power and ground for a 920W amp, if it is a 920W amp you would need at least a 4ga power and ground, but then again if the amp only has a 40A fuse its not a 920W amp unless that is max power, maybe, with a 40A fuse it's a lot closer to 300W RMS. and as the 12" Kicker comps where 300W continues you are underpowering the subs by about 1/2 and that means you are probably overdriving the amp into "clipping". and that is not good for the subs or the amp and probably why the fuse went, also a lack of current is not helping, even a 300W amp needs an 8ga power and ground.
What is the model number of the amp? 94
Old Apr 27, 2006 | 01:29 PM
92BluEH-3's Avatar
lulz
Default Re: Quick Question on fuses (fcm)
i dont know hang on ill look....KAC-7202 i it is a 920 peak power im not sure on the rms but no need to flame me on a system and i didnt wire up. if i would have done the wiring it would have been done a lot better.
GsDAteg
Audio / Security / Video
13
Mar 14, 2010 07:54 AM
Spazbaboon
Feb 26, 2007 03:36 PM
ilikemyaccord
Aug 13, 2004 04:36 PM
GoodFella
Jul 18, 2001 05:18 AM
rave n race
Jun 8, 2001 09:53 PM
