quick cap question
Old Feb 19, 2009 | 10:42 PM
hatcht9x's Avatar
Icon2 quick cap question
So I have a 1.2 farad cap (Tsunami) and I am a little confused about the wiring, Yet, it is a simple question.. In the diagram, The power wire is depicted as going to the terminal to the left of the display screen. However, in the plastic cover It says the power wire goes to the terminal to the right of the screen.. SO! does it even matter? I ran it for a bit, wired as seen on the diagram.. and everything worked fine.. Headlights still dim on big bass hits (but the car is 20 years old), but I took thee cap out today to tighten down one of the terminals and I was just wondering what you guys thought..
Old Feb 20, 2009 | 08:31 AM
nsxxtreme's Avatar
Default Re: quick cap question
Yes it matters if you hook it up backwaord it can explode. Turn the cap around and now the cap matches the intructions
Old Feb 20, 2009 | 10:15 AM
hatcht9x's Avatar
thanks for the info.. but are you sure? and/or how do you know
Old Feb 20, 2009 | 02:10 PM
tilegend's Avatar
usually capacitors will have a reverse polarity protection.
i looked at the instruction manual for the PP912UM-CAP (not sure if its the same model as yours but its also a 1.2 farad tsunami cap.
and the diagram has it how your cap actually is.
looking at the cap from the digital screen the negative terminal is on the left and positive is on the right
http://akamaipix.crutchfield.com/Man.../120PP912U.PDF
i would go with what the cover on your cap says.
Old Feb 20, 2009 | 03:59 PM
hatcht9x's Avatar
really good info man! thanks!
and yea I actually called tsunami today and they verified that I should go by what the cover on the cap says.
Thanks again for the info!!
stackz
Audio / Security / Video
Mar 5, 2007 12:21 PM
R Thizzel
17
Nov 22, 2004 05:48 PM
JustinG60
Nov 12, 2004 05:40 AM
hollywood30002
Jun 23, 2004 05:30 AM
Agent STFU
Mar 18, 2003 02:11 PM
