Questions about battery relocation
Old Nov 6, 2008 | 06:07 PM
88efZ6's Avatar
Default Questions about battery relocation
First question- Is the Odyssey PC625 a good battery for a relocation and cold winters?
Second question- How much 0 gauge wire to buy and how much 4 gauge?
Old Nov 6, 2008 | 06:15 PM
Davus's Avatar
Default Re: Questions about battery relocation (88efZ6)
It takes about 17 to 20 feet to reach the trunk (go for 20 just to be secure) of 0 gauge. I'm unsure where the 4 gauge comes into play, unless you are upgrading the grounds? If so, about 10 ft or less would be fine.
Old Nov 6, 2008 | 06:28 PM
88efZ6's Avatar
Default Re: Questions about battery relocation (Davus)
4 gauge comes in after the distribution block because on older Honda's run the starter and fuse box both directly from the battery
Old Nov 6, 2008 | 09:07 PM
Davus's Avatar
Ah of course. I should have realized this, I just upgraded those wires. Like, 6 hours ago.
I used about 3 feet from alternator to block, probably 1.5 to 2.5 ft from block to starter, and less than a foot from the block to the fuse box. 8 feet or so should get you by nicely. That's of course assuming you're upgrading those wires. I used the terminals ("4 to 6 gauge") from AutoZone to connect the various ring connectors, they fit nicely (just as reference).
E: This was on a 6th gen '96 Civic though, mileage may vary now that I think about it.
Old Nov 6, 2008 | 09:34 PM
88efZ6's Avatar
I'm gonna use my stock wire alternator to fuse box because 4th gens have a fuse right there.... I think its for that anyway but with the wire tuck it still reaches so thats all that matters to me.
Old Nov 6, 2008 | 10:58 PM
Davus's Avatar
Also I'm just curious, what brand wire will you be using, and from what place?
I've always had a first choice with a particular company, just curious if there's something better out there. :-)
Old Nov 7, 2008 | 05:34 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88efZ6 &raquo;</TD></TR><TR><TD CLASS="quote">4 gauge comes in after the distribution block because on older Honda's run the starter and fuse box both directly from the battery </TD></TR></TABLE> Skip the "distribution block" run the "0 gauge" directly to the starter motor and then run an 8ga with a 100A in-line fuse, or 4ga with a 150A in-line fuse] from the starter motor to the fuse box, it's a much better way to go because it eliminates a bunch of connections. 94
Old Nov 7, 2008 | 07:26 AM
88efZ6's Avatar
Default Re: Questions about battery relocation (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Skip the "distribution block" run the "0 gauge" directly to the starter motor and then run an 8ga with a 100A in-line fuse, or 4ga with a 150A in-line fuse] from the starter motor to the fuse box, it's a much better way to go because it eliminates a bunch of connections. 94</TD></TR></TABLE>
I'm trying to eliminate wires in my engine bay my fuse box is inside the car so that would mean having an ugly junction under the hood and I don't want that
Old Nov 7, 2008 | 12:38 PM
Davus's Avatar
Sort of off topic note: Hope this tuck turns out nicely for you. I'm in for pics during the process.
Old Nov 7, 2008 | 08:09 PM
88efZ6's Avatar
Default Re: (Davus)
Sorry man I didn't take any no camera.... its all done all I need to do is relocate the battery and fire it up.. Car was a mess when I got it but I made due with what I had because of lack of funds.
JuneBugDrfter
Feb 26, 2013 11:49 AM
dylaxiin
May 11, 2011 07:11 PM
AntMan401
Feb 19, 2008 09:50 PM
87-EF rEx
Oct 9, 2005 11:52 AM
lsvtecrocket
28
Jan 8, 2004 09:28 PM
