question on wiring subs to amp
Old May 30, 2003 | 12:32 PM
shipsaeki's Avatar
Default question on wiring subs to amp
ok, I have two 10 inch subs in a box that arent wired yet. behind where the sub fits, are the terminals. Since there are two subs, there are two terminals. My question is, would I be able to wire the subs up to both terminals, then after i wired them up to connect both positives from both subs and both negatives from both subs, crimp them and then connect to the amp so i basically only have 1 neg and 1 pos going into my amp
Old May 30, 2003 | 01:31 PM
shipsaeki's Avatar
Default Re: question on wiring subs to amp (shipsaeki)
anyone?
Old May 30, 2003 | 02:34 PM
vteg's Avatar
New User
It is possible, depends on your subs and amp. You have to make sure that the load is correct after you wire them in series or parallel.
Old May 30, 2003 | 02:35 PM
shipsaeki's Avatar
Default Re: question on wiring subs to amp (vteg)
what exactly does that mean?..."series or parallel" can you explain that to me... my friend told me the same thing but signed off b4 i could ask him what it meant.
Old May 30, 2003 | 03:30 PM
shipsaeki's Avatar
no more help? I need some help... i want to know if it safe to do so. I don't want to be blowing my amp and subs up
Old May 30, 2003 | 04:39 PM
Xsi's Avatar
Xsi
Heres a giude: http://www.rockfordfosgate.com/rftech/wiringwizard/
But it's simplest just to wire one channel to each sub
Old May 31, 2003 | 10:43 PM
Synergy001's Avatar
the way you are describing it is connecting it in parallel. if your subs are both 4 ohms then it would make it 2 ohms. if your amp is capable of handling that then it should be fine.
Old Jun 1, 2003 | 07:19 AM
Xsi's Avatar
Xsi
We need to know whether your subs are dual voice coil and what ohm load your amp can take
civictildeath
Audio / Security / Video
Apr 8, 2009 01:57 PM
supracrx
Feb 14, 2007 11:35 AM
GroundZer0 336
Apr 17, 2004 08:54 AM
GroundZer0 336
Aug 21, 2003 09:49 AM
JTCdudeman
10
Jan 20, 2003 09:40 PM
