question on power door locks
Old Jun 25, 2008 | 03:49 PM
91EF919's Avatar
Default question on power door locks
i have a 91 civic hatch, and i am installing a viper 5900 car alarm, and also power door locks. I installed the acuators, and everything, plugged them to 2 relays 1 for lock and the other for unlock. I try to see if it works with the alarm, it only locks, but doesn't unlock. I flip the relays, because could be a bad realy but it locks on the other relay but no unlock. I know the acuators work cuz i tested them on a 12v battery, can someone tell me whats wrong, or do i have the wrong diagram for the relays.
Old Jun 25, 2008 | 04:51 PM
B18C_EJ8's Avatar
You have the relays wired wrong.
http://www.the12volt.com/doorlocks/page3.asp#arp
Old Jun 25, 2008 | 05:10 PM
91EF919's Avatar
Default Re: (B18C_EJ8)
i used that same diagram from the12volt.com
Old Jun 25, 2008 | 05:13 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: (91EF919)
Tap ground to the unlock trigger to see if it will lock. If you followed that relay it should be 85 pin on the unlock relay. Its the trigger wire from the alarm.
Old Jun 26, 2008 | 06:31 AM
91EF919's Avatar
Default Re: (wrx-killer-Sti-eater)
ok i will try to see if that works if it doesn't then i will post up here again. Do u think i blew the unlock on the alarm? I used the wrong diagram the first time, then i found out i used the wrong one and i used that one above.
Old Jun 26, 2008 | 05:24 PM
91EF919's Avatar
ok i got the acuators to work, and finished the whole alarm today. Very good alarm i will recconmend this alarm who ever is looking for a good 1 mile range alarm.
si90rex
Audio / Security / Video
Nov 18, 2008 04:55 AM
doubleoazn03
Oct 17, 2008 06:07 PM
AARON RLH
Sep 16, 2008 02:15 PM
Dub C
Apr 4, 2006 08:42 AM
slowturtle
Apr 29, 2005 06:59 AM
