question about speaker installation
I took off the cover and speaker from the rear, and there is a harness. I detached it from the speaker and took the speaker out. the new speakers I have don't have that same clip that the oem speakers did. my question is, can I pop off the old clip from the oem speakers? or can I buy them from somewhere else? because I tried popping it off and it's like stuck on there.
Although you haven't told us make & model of the car, you can go to Best Buy or Circuit and buy the speaker harness plugs. The spade connectors will attach to the terminal plate on the speaker, and it's plug & play from there....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">Although you haven't told us make & model of the car, you can go to Best Buy or Circuit and buy the speaker harness plugs. The spade connectors will attach to the terminal plate on the speaker, and it's plug & play from there....</TD></TR></TABLE>99 honda civic hatch.
alright so something like this, http://www.circuitcity.com/ssm...il.do should work?
I'd actually recommend just cutting the factory clips off, save yourself the 4 bucks lol...might get a better connection if you solder the new leads on anyway, only my .02
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowSOHCvtec »</TD></TR><TR><TD CLASS="quote">I'd actually recommend just cutting the factory clips off, save yourself the 4 bucks lol...might get a better connection if you solder the new leads on anyway, only my .02
Or, you could not be ghetto and use the connectors... This will enable you to easily reinstall the stock speakers should you decide to sell/trade the car...
</TD></TR></TABLE>Or, you could not be ghetto and use the connectors... This will enable you to easily reinstall the stock speakers should you decide to sell/trade the car...
thanks for help guys. I just got back from putting them in. the only modification I had to do to the harness was cut out the male terminal and replace it with a female one. because the speakers I have only had female
thanks again speakers sound great
jthm
Audio / Security / Video
Sep 18, 2007 05:51 PM
tweekerz
Aug 11, 2004 05:34 PM
