Question about Installing an Amp
Old Oct 28, 2008 | 06:09 PM
dth0ng69's Avatar
Default Question about Installing an Amp
Okay i've just bought a new amp for my System, and need to rewire for lower gauge power wires..
I kinda forgot how to remove the kick panel trim, and the rocker panel trim, and basically all the trims that you need to take out to wire the power wires and RCAs.
I have a 96 civic Sedan. Which trim do i begin to take out first? i want to know the proper way of doing this so i don't damage anything like i did last time.
thanks
Old Oct 28, 2008 | 06:56 PM
It Wasn't Me's Avatar
Just start pulling pieces out. If they're resistant, look at the piece it's binding with and remove it first. It's not a difficult process.
On a side note: It's not a good idea to run your RCA's and power wire next to one another.
Old Oct 28, 2008 | 07:13 PM
KRock459's Avatar
Default Re: Question about Installing an Amp (dth0ng69)
Start with the kick panel, its held on by clips and it pulls toward the center of the vehicle, may have a screw on plastic nut/washer up high as well. Next is the threashold panel, it has clips on the bottom (about 4 clips). You pull gently on the pieces trying not to bend them, preferably in a garage with some heat, cold plastic gets pissed when you try to play with it.
Just remember....plastic always bends before it breaks
Kirk R
Old Oct 28, 2008 | 07:29 PM
Front to back is usually how the process goes. My car's an oddball. I had to remove the kick panel and rear passenger panel, before I could remove the piece on the door sill. Unless I wanted to break the tabs, that is.
Old Oct 30, 2008 | 10:21 AM
dth0ng69's Avatar
Default Re: (It Wasn't Me)
Alright.. im guessing to put everything back together correctliy you start from the back to the front..
szczerbanator
Audio / Security / Video
May 25, 2009 09:07 PM
hometheaterman
10
Jan 15, 2008 06:14 AM
pgFA
Apr 24, 2007 12:17 AM
vidanator
Feb 25, 2006 06:34 PM
pnthr30
Jul 8, 2003 04:47 AM
