question about harness.
Old Dec 27, 2007 | 09:36 PM
superdat1's Avatar
Default question about harness.
so the guy who i bought my car from had an aftermarket cd player installed in it. instead of buying a wiring harness he just cut up the stock one can someone tell me how i can replace this? is the harness just one or is it connected to a bigger harness. TIA
Old Dec 27, 2007 | 10:14 PM
White Smoke's Avatar
i my honda
Global Mod
Default Re: question about harness. (superdat1)
It's usually connected to the dash harness so you would have to splice in a stock plug.
What car is this?
Old Dec 28, 2007 | 07:33 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: question about harness. (White Smoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">It's usually connected to the dash harness so you would have to splice in a stock plug.
What car is this?</TD></TR></TABLE>
Man, you should know that Metra makes harnesses for OEM radios... what kind of car is this? 98 LS?
If thats the case, the wire harness model is 71-1720.
Then, get 70-1720 to wire to your aftermarket stereo.
Old Dec 28, 2007 | 08:11 PM
a_joshchang_story's Avatar
go to car toys and buy a cheap deck and they will clean it up and install a new one. might cost a dollar or two but hecka hella clean. dizzle
Old Dec 29, 2007 | 05:47 AM
fcm's Avatar
fcm
Old Fart
Unless you want to install an OEM HU, [Honda/Acura] just hard-wire the aftermarket HUs harness to the cut OEM radio harness leads, this will help... http://www.installdr.com/Harnesses/HA-Wiring.pdf
If you do want to install a stock HU, do as JDM_Ej suggests, get the "reverse" harness, most car audio shops will stock them, they will be $10 or so, a new (used] dash harness will be at least $100, [pick a part] plus a dash pull. 94
BTW I see no point in installing the "reverse" harness so you can get a harness adapter to install an aftermarket HU.
Old Dec 29, 2007 | 04:51 PM
superdat1's Avatar
mm. well the reason i wanted to do this is because it looks like crap. just wanted to get everything tidy. thanks for the info! and yeah its a 98 LS
Old Dec 29, 2007 | 07:03 PM
fcm's Avatar
fcm
Old Fart
Default Re: (superdat1)
A soldering iron and some shrink tube and a short piece if convoluted tubing, [wire loom] and some electrical tape and the aftermarket HU harness and you can clean it right up and make it look like the aftermarket HU plug came stock with the car.
I do the above all the time, it's a lot cheaper and a hell of a lot easier then replacing the dash harness, [by a lot], and cleaner then installing the reverse harness, [or OEM radio plug] and then having to add the harness adapter so you can install an aftermarket HU and plug it into the OEM radio harness plug.
First, it's $10-$20 worth of plugs you do not need.
Second, it eliminates 4 connections.
Third, it's less work and a cleaner, as it eliminates the bulk of the 2 plugs and their wiring.
Again, this assumes you are installing an aftermarket HU, not a stock HU. 94
Old Dec 30, 2007 | 12:42 AM
superdat1's Avatar
fo sho. thanks for the idea fcm
Jdm Blood
Audio / Security / Video
Aug 19, 2009 10:22 PM
imadigitalgod
Mar 6, 2009 09:25 PM
ilikemyaccord
Aug 13, 2004 10:37 PM
giff74
May 9, 2004 04:06 PM
type r 01-1063
Dec 10, 2003 02:00 PM
