protection against window stretching?
Old May 27, 2004 | 01:00 PM
slappiecappie's Avatar
Default protection against window stretching?
I have recently found out that window stretching is a weakness for 94-7 accord models (not sure about other models). After moving the rubber behind the glass it is possible to "strech" the window about a 1/4 inch out without smashing glass to open doors.....alarm will go off eventually, but it gets theives past shock sensor alarms and gives them enough time to get to the battery to disconnect most alarms even after they go off.
are there any add on pieces a body shop can throw on to protect the window?....for example it was near impossible to pry my old taurus....
Old May 27, 2004 | 08:06 PM
Auex's Avatar
Default Re: protection against window stretching? (slappiecappie)
Buy a glass break sensor for your alarm. Then turn it up to the point if someone tries to stick a screw driver, slimjim, or any kind of metal rubbing on the glass that it will go off.
Old May 27, 2004 | 11:10 PM
skrewdriver88's Avatar
Default Re: protection against window stretching? (Auex)
How much is that sensor that your are talking about cost? and how does it hook up to your alarm system that is already installed?
TIA
Old May 28, 2004 | 12:36 PM
Default Re: protection against window stretching? (skrewdriver88)
Old May 28, 2004 | 02:32 PM
rjr162's Avatar
actually your best bet is a prox sensor. The glass brake won't detect what you're talking about, but a prox would
Old May 28, 2004 | 05:17 PM
Default Re: protection against window stretching? (rjr162)
how much is a prox sensor and how hard is it to hook up to a python 460HP car alarm?
Old May 29, 2004 | 08:24 AM
foz's Avatar
foz
around here dei (python, viper etc...) normally hook them up anywhere from 125-185
Old May 29, 2004 | 02:33 PM
Auex's Avatar
Around 70 for the glass break sensor. The downside to the proximity sensor is that it has a tendancy to false alot.
Old May 29, 2004 | 04:28 PM
K. so what would you guys suggest a proxy or a glass break sensor?
Old May 30, 2004 | 05:54 AM
rjr162's Avatar
if you setup the prox correctly it won't false, except for here in the north east mine "falsed" when we had serverly heavy rain or hail. Other than that, I never had a false from it. The prox will run around $110-$140 at most places. Check around. I had a ton of luck with the DEI unit for all the customers I put it in.
Old May 31, 2004 | 10:28 PM
yeah we don't get much rain here in Phoenix, Arizona
Old Jun 1, 2004 | 05:43 AM
o_Rage_o's Avatar
go prox. If you have dual stage you can have the added benifit of interior and exterior triggers. If you set your exterior just a shy past the window pane and before the end of your mirrors you have a good warn away zone that should'nt false.
The interior should be up to the inside window and together they will effectivly warn and go off if anything should happen.
the sensor is like $27, the install is up to the installer. It can be added to a factory alarm by diode isolating each trigger on the original shock sensor, and should be mounted in a central location (like under the handbrake)
-Shane
Old Jun 1, 2004 | 07:31 AM
Default Re: protection against window stretching? (o_Rage_o)
k. thanks for giving me some advise about the proxy sensor. How big is the proxy sensor?
zsudz922
Audio / Security / Video
12
Oct 7, 2009 12:22 PM
saanemon
11
Nov 24, 2006 12:53 PM
geminis2k
Aug 25, 2003 08:27 AM
gumbii
Feb 16, 2003 08:51 PM
HeikDiesel
12
Aug 16, 2002 01:50 AM
