Problems with Kenwood deck
Old Feb 2, 2005 | 12:13 PM
untitledsn41's Avatar
Default Problems with Kenwood deck
to start it off the deck is about a year old and is a Kenwood KDC-722. and the problem i am having only happens about 50% of the time i use it.
The problem is that sometimes while playing cds that the music starts getting really scratchy, sometimes it is very faint and other times it is impossible to listen to the cd. i know it isnt my amps or loose speaker wires or anything because i switch it over to Tuner and the radio plays normally. so does anyone have a suggestions in what i might do to fix it?...
Old Feb 2, 2005 | 02:42 PM
rawkus's Avatar
Default Re: Problems with Kenwood deck (untitledsn41)
The best I could recommend is checking all the RCA's to make sure they are connected properly. Checking all the speaker, power, ground, and remote wires. I would start with the grounds and speaker wires. If they are all fine, it's prob an internal problem so you will have to have that checked out by a Kenwood dealer or something.
Dan
Old Feb 2, 2005 | 03:28 PM
Default Re: Problems with Kenwood deck (rawkus)
i'll pop out the deck when i get home from work. thanks for the advice
Old Feb 2, 2005 | 10:23 PM
CereaLand's Avatar
I had the same problem as you. Kenwood eXcelon Deck model x579 i think, used just over 1 year. Never could figure out the problem. Sometimes it work perfectly, something it sounds like the disc is all scratch up, then it start making all kind of weird noises. I go rid of it and got a pioneer.
Kenwood
Fo-Do Fanatic
Audio / Security / Video
Dec 4, 2010 11:07 AM
tegman85
Jul 19, 2007 10:08 AM
LoseRPunKx182
Jun 5, 2005 02:47 PM
ap716
May 8, 2005 08:37 AM
Mandella
Apr 27, 2005 09:38 AM
