Problem with System
Old Apr 18, 2004 | 06:21 PM
2ksilverex's Avatar
Default Problem with System
Okay heres my deal, Ive tried using 2 diff amps so ive kinda ruled that part out. I have a Kicker 15 Comp VR.....
My problem is when I hook up my amp, sub, etc I get connection, power, everything.
Power is fine until the bass hits, then my amp goes in to Protect.
Any ideas of what it could be???
Old Apr 18, 2004 | 07:40 PM
john666's Avatar
Default Re: Problem with System (2ksilverex)
I had that problem once.. in my case it was a loose wire inside the box, when the sub would hit it would also go into protection. at a lower volume it would b ok. but only when i crank it up it would go to protection.. might want to check the wires from the amp to the sub and also the wires inside the sub.
Old Apr 18, 2004 | 09:02 PM
DELTEGRA's Avatar
also check your ground wire is the same gauge as the power wire, short, and very well connected to a bare metal chassis surface
Old Apr 20, 2004 | 09:53 AM
spark plugs.
Guest
Posts: n/a
Default Re: Problem with System (DELTEGRA)
sorry to say...but if all the wiring is in place and well secured...you've blown your sub. try using a diff. sub and see what happens.
98civdx
Audio / Security / Video
Jan 3, 2012 09:12 PM
Chiito4
Sep 12, 2010 07:37 AM
accord64
Oct 1, 2007 06:32 AM
Bklyn TSi
13
Aug 21, 2003 07:26 PM
beef3000
May 28, 2003 05:18 PM
