problem with audio system wiring??
Old Jan 31, 2003 | 12:43 PM
blktyper919's Avatar
Default problem with audio system wiring??
hi recently as i hit dips or bumps on the road my sound turns off but the radio is on..for example the cd player is still going but my sound goes off???im wondering what can cause this and how to fix ...it happened in my sisters old integ as well..i was thnking it was bekus of the wiring but i tried to look on my amps and i looked behind the head unit..its getting annoying bekus if the sound wants to turn off it will and wen it wants to turn on it will...thanks>...
Old Jan 31, 2003 | 12:46 PM
1BlackHatch's Avatar
Default Re: problem with audio system wiring?? (blktyper919)
Check the ground on your amps.
Old Jan 31, 2003 | 09:21 PM
clm's Avatar
clm
Default Re: problem with audio system wiring?? (1BlackHatch)
...along with all the other wiring. Most likely it is the ground wire rocking loose, though.
Old Jan 31, 2003 | 11:06 PM
Default Re: problem with audio system wiring?? (clm)
thks for your replys....how do i go about located that ground wire??i dont know much about audio systems..
Old Feb 1, 2003 | 06:57 AM
clm's Avatar
clm
Assuming the installer did a good job, the ground wire will be the shortest of the thicker wires that is mounted to the chassis of your car from your amplifier. When you check it, make sure it's secured down and there's no paint at the contact the point.
bcintron95
Sep 12, 2013 01:30 PM
bmxkills
Audio / Security / Video
Oct 21, 2009 02:39 PM
jdmfreek671
Nov 18, 2002 01:26 PM
NiiS
Sep 17, 2002 10:12 AM
DC2_Integra
Jun 7, 2002 02:06 AM
