Power wire not on?
Im usen a 1000watt amp and for some reason the remote wire is on but not the power? i tryed all kind of size of power wire and all my fuses are 30's what could be the problem?
ive used a 400watt amp before and it worked perfectly fine..i went and exchange this new 1000watt amp and still no power
ive searched but found nothing on the site
Wattage of the amp has nothing to do with anything...
And what the hell does this mean:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">i tryed all kind of size of power wire and all my fuses are 30's what could be the problem?</TD></TR></TABLE>
You should have one fused wire going from the positive terminal on the battery to the power (+) terminal on the amp. There should also be a ground wire from the ground (-) terminal on the amp.
Have you verified with a test light or multimeter that there is power at the positive terminal on the amp? If you test the amp end of the power wire and there's no voltage, then there is no connection to the battery.
Yup did that, damn i should of thought about testing the power wire i'll do it again maybe tomorrow. what i mean is the Amp power isnt on lol my bad
nah its not blown its peak and its an interfire IB-2900C amp
http://www.interfireaudio.com/...2.htm
Modified by DynastyRacer22 at 2:59 AM 3/22/2006
Well if you have power on the amps power lead and turn on, [amp control] lead and a good ground and the amp still will not turn on your Interfire amps fire has gone out.
A few other things, when you are checking for power on the power lead at the amp, are you doing it with the system on?
What size and kind if fuse in on the power cable by the batt.?
What are you using to test, a multimeter or test light?
94
94
my old amp is da same kind and i still have the same problem then i took it back to the car audio place and exchange it so i got a new one and still same problem and the amp is only about 2 weeks old man ionno i give up and i just sold my car too so maybe im gonna have another problem with this amp in my new car haha
hybrid1990crx
Audio / Security / Video
14
Jul 14, 2006 06:46 AM
