cruise control button for high/low boost
my cruise control has been removed and i'm having a little difficulty wiring my boost controller to the cruise control button in my dc2.
im using a turboxs dual stage which is controlled by my ecu, but is still dependent on it being activated or not.
i had a toggle switch but wanted to go with something a little more low key.
the controller has a relay at the ecu...the ecu controls high boost through certain parameters set in the ecu.
i have the ground and the power spliced to the crusise control button's harness, one at the green and one at the black, but now when the switch is presed in, the indicator light isn't coming on.
anyone have any experience, i checked in the archives and didn't find too much info.
Stopsign32v
May 1, 2011 04:07 AM
