question for audio people...
Old Jul 5, 2003 | 08:57 PM
ilikemyaccord's Avatar
Default question for audio people...
i finally got a remote wire hooked up to my panasonic deck to my amp...i have a jbl 600.1 powering a kicker 15" l7..yea i kno im not pushing it alot but would you guys suggest me to upgrade a new battery..i have a phoenix gold cap lying around uninstalled yet but my long term plan is also get an amp to power my mb quartz...would an upgrade to a better battery and installing my cap be good..or jus install the cap...ive had problems before when i left my switch to the amp on and my car is dead and its a hassle to get it jumped..i think even with the remote wire...my car battery will still be drained when i turned it off and over nite the battery will go dead...is my theory correct or not?..and if i should get a new battery, what brand would yall suggest...thanks
Old Jul 5, 2003 | 11:33 PM
PetroGuyX's Avatar
do u have a honda battery or an aftermarket one?
Old Jul 6, 2003 | 06:33 AM
pickup1's Avatar
if you hook up the remote wire,the amp wont come on unless the radio is on.a better battery is always a good idea.optima makes a yellow top that is real good.the cap is a good idea also,especially on music peaks.your headlights wont dim as much!if you remote wire is hooked up correctly,your battery wont be dead in the mourning.i have a shitty autozone battery in my civic with a jl 300/2,a rockford db1000 and a alpine 3553.it works fine,just cant play the radio with the car off for a long period of time.my svr battery just took a dump.if you cant afford a better battery,just use the cap.
Old Jul 6, 2003 | 09:44 AM
Torridcivic's Avatar
Default Re: (pickup1)
Here is my two cents.
If right now your only pushing 600 you don't need a new bat. YOu have a cap, and that will help. But if you do get another amp then it is time to think about a new bat. if the one you have now is working fine, maybe you could live with it until it dies and then just spend more on a bat rather then buying a completely new one when you don't need it.
Old Jul 6, 2003 | 06:20 PM
Default Re: (Torridcivic)
thanks alot guys four your opinions...ill go ahead and install the cap and itll work out...in the long run ill probably purchase a new battery..opitma probably when i amp up my mb quartz
Rttix1337
10
Jan 20, 2014 03:50 PM
03djmAccrd
Jul 9, 2010 12:13 AM
adrianl211985
Audio / Security / Video
Jun 2, 2004 09:03 AM
GroundZer0 336
13
May 23, 2003 06:10 AM
