Ignition Wire ??
Old Apr 9, 2007 | 11:28 PM
Extreez's Avatar
Default Ignition Wire ??
What wires can i connect my radar detector beside the cigarette lighter for it to run with ignition. I dont want anything going to my cigarette lighter so i need a positive and negative wire to connect to and have it running wit ignition, any idea any one?
?? Tap in fuse ??? i have no expierence with this someone help if its possible, what fuse and how
btw is a 93 integra.
Old Apr 9, 2007 | 11:30 PM
suspendedHatch's Avatar
Default Re: Ignition Wire ?? (Extreez)
First you'll have to tell us your year/make/model.
Old Apr 9, 2007 | 11:33 PM
Extreez's Avatar
Default Re: Ignition Wire ?? (suspendedHatch)
oh sorry lol 93 integra
Old Apr 10, 2007 | 05:48 AM
fcm's Avatar
fcm
Old Fart
Answered on G2IC. 94
Old Apr 10, 2007 | 05:52 AM
perseverance's Avatar
hook it up to your accessory wire on the ign harness. get urself a multimeter and test the big gauge wires for a wire that's 12 volts only when the key's on accessory or the vehicle is started but not when the vehicle is cranking. if u can't do that then i suggest you get it installed professionally.
Old Apr 10, 2007 | 04:07 PM
fcm's Avatar
fcm
Old Fart
Default Re: (perseverance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perseverance &raquo;</TD></TR><TR><TD CLASS="quote">hook it up to your accessory wire on the ign harness. get urself a multimeter and test the big gauge wires for a wire that's 12 volts only when the key's on accessory or the vehicle is started but not when the vehicle is cranking. if u can't do that then i suggest you get it installed professionally.</TD></TR></TABLE>Why would you not use the power free pins on the fuse box, that's what they are there for, [adding accessories]? 94
Old Apr 10, 2007 | 04:15 PM
sorry... i didn't kno about those pins. i just use the ign harness cause i'm guaranteed that what i'm looking for is there. sheesh... if he wanted to he can get it at the radio harness. i may try that one day... but i kno for sure the ign will work.
Old Apr 11, 2007 | 04:19 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perseverance &raquo;</TD></TR><TR><TD CLASS="quote">sorry... i didn't kno about those pins. i just use the ign harness cause i'm guaranteed that what i'm looking for is there. sheesh... if he wanted to he can get it at the radio harness. i may try that one day... but i kno for sure the ign will work.</TD></TR></TABLE> So do the free pins, as I said that's what they are there for, you will find a 12V+ constant, [hot at all times] a 12V+ 2nd ign., [hot in run only] even a 12V+ park light, [hot when park or head lights are on] the park light free pin can also be used as an input, [park light flash from alarm or key-less entry unit]. 94
so_cal_prelude
Jun 18, 2007 01:53 AM
sz9182
Audio / Security / Video
Apr 30, 2007 08:27 PM
staticrex
Dec 8, 2004 11:46 AM
CrazyModGSR
Sep 16, 2004 09:55 AM
tyflip2
Jun 14, 2004 03:08 PM
