Power Locks & new Headunit
Rumor is that if u have power locks and you remove the OEM headunit, your power locks/keyless entry wont work? This true? if so how do i bypass it?
(note: i dont have Honda keyless entry, i have the remote for my alarm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2EK »</TD></TR><TR><TD CLASS="quote"> This true? if so how do i bypass it?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">(note: i dont have Honda keyless entry, i have the remote for my alarm) </TD></TR></TABLE>
If you're not using the Honda OEM remote for your locks, then you do not have to worry about the factory keyless.
Upgrade away.
Upgrade away.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">
Upgrade away.</TD></TR></TABLE>Ditto that, even if you did not have the aftermarket alarm, pulling the stock HU would only disable the key-less entry, the power door locks would still work, however, unplugging the stock HU, [aftermarket alarm or not] will disable the dome light, [door activation] and a jumper can be had... it comes with this harness adapter... http://www.scosche.com/scosche...HAK3B, or you can go ghetto and just get one of these... http://www.scosche.com/scosche...HA02B and make your own jumper, [cut the 2 leads that are jumped off the oem plug and connect them together].
94
94
silentbeatz
Nov 9, 2007 09:39 AM
99lspwr
Jun 20, 2006 09:20 AM
BigPlansNoMoney
Audio / Security / Video
Nov 9, 2004 07:15 AM
