Power inverters
Old Nov 9, 2003 | 09:31 AM
Torridcivic's Avatar
Default Power inverters
I am wondering how big of one I would need to plug in a home audio DVD/Mp3 player, There are one for sale from 100 watts to 3500 watts, what do I need? Are there any brands I should look for or stay away from?
Old Nov 9, 2003 | 01:04 PM
nsxxtreme's Avatar
Default Re: Power inverters (Torridcivic)
Read the back of you DVD player it should say what is required.
Old Nov 10, 2003 | 01:33 PM
Default Re: Power inverters (nsxxtreme)
Right but I don't think that it is measured in watts, what is the amp to watt ratio on a power inverter?
Old Nov 10, 2003 | 03:06 PM
B18C_EJ8's Avatar
Every electronic device that plugs into the wall should have a label on it that shows power consumption. My DVD player says 14 watts, and my GameCube draws 39 watts. Look on the back near where the power cord enters the case.
Old Nov 11, 2003 | 11:58 AM
Mikeman191's Avatar
the 350 rms / 700 watt peak should be enough... they sell them for like 40 bucks at walmart... Just start there, and if it trips the protection, just return it... walmart returns dept
Old Nov 12, 2003 | 03:38 PM
Default Re: Power inverters (Mikeman191)
Thanks guys I'll let you know what I get.
Old Nov 14, 2003 | 01:32 PM
PupaScoopa's Avatar
The formula for power is: P/V=I or IV=P so if your DVD player draws 1A, then: .5a*120vac = 60watts.
^^^ EDIT: I stand corrected, what the hell was I smoking?? It's fixed now. Thanks vteg!
Modified by PupaScoopa at 9:01 AM 11/15/2003
Old Nov 14, 2003 | 06:48 PM
vteg's Avatar
New User
Default Re: Power inverters (PupaScoopa)
I think it is P=IV. So it would be 120 watts at 1 amp.
Old Nov 14, 2003 | 10:03 PM
Mikeman191's Avatar
Default Re: Power inverters (vteg)
Watts = Volts * Amps.. But...
The inverters are rated at 14.4 volts, not 12. so you have to keep in mind everytime you turn on your lights, or your sub hits, or your alternator isnt running, the wattage specified for the inverter drops... Just get the cheapest one thats rated at least 1.5 times your power needs in continuous power (not peak!)... unless you buy a true sine wave inverter, they all do the same thing..
Old Nov 15, 2003 | 06:12 AM
PetroGuyX's Avatar
why in the hell are you putting a home audio dvd player in your car sir?
Old Nov 15, 2003 | 12:36 PM
vteg's Avatar
New User
Default Re: (PetroGuyX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PetroGuyX &raquo;</TD></TR><TR><TD CLASS="quote">why in the hell are you putting a home audio dvd player in your car sir?</TD></TR></TABLE>
I would guess because they can be had brand new for very cheap.
Old Nov 16, 2003 | 02:15 PM
andyep3's Avatar
I did the same thing (home DVD playerk, $40 apex one and a $50 lcd screen, works fine). I bought the ~$50 one at Walmart, I can't remember the exact rating on it, but it works fine. Now I just need to hardwire it...
Old Nov 16, 2003 | 03:46 PM
Default Re: (andyep3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andyep3 &raquo;</TD></TR><TR><TD CLASS="quote">I did the same thing (home DVD playerk, $40 apex one and a $50 lcd screen, works fine). I bought the ~$50 one at Walmart, I can't remember the exact rating on it, but it works fine. Now I just need to hardwire it...</TD></TR></TABLE>
This is the reason, You can get the 1/2 sized (1/2 of a normal DVD or CD changer or something) for $60 at radio shack, lets see $50 for and inverter + $60 for a player + $150 for an LCD screen =5 $260
$1500 - $260 = a lot of money saved. (assuming you already have a head unit with audio inputs to amplify the sound)
Andyyep3, do you have any problems with the DVD skipping?
silk509
Audio / Security / Video
16
Jul 20, 2009 03:26 AM
KID_DEATH
Northern California (Sales)
May 16, 2007 02:18 PM
only1crx
May 19, 2004 06:56 PM
miksew
May 2, 2004 05:06 PM
jdmstreethatch
Jan 21, 2004 10:26 AM
