power to dside speaker question...
Old Dec 22, 2008 | 06:02 PM
henwon's Avatar
Default power to dside speaker question...
i'm trying to install some new front speakers in my civic, it did not have a front d-side speaker when i got it. when i tried to install one, i noticed there was no stock wiring inside the door. as i looked around i noticed i noticed a wire tucked between the door and the fender. my question is, will this power the front speaker? if not can you guys help me out...
thanks.
Old Dec 22, 2008 | 09:09 PM
henwon's Avatar
Default Re: power to dside speaker question...
bump...
Old Dec 24, 2008 | 05:14 AM
fcm's Avatar
fcm
Old Fart
Need a much better pix. 94
Old Dec 24, 2008 | 05:48 AM
KRock459's Avatar
^^ better pic would help here as well, but it looks to be the factory door molex, your missing the door side of the harness. Wire colors are Blue (+) and Gray (-) for speaker if you try to use what you have. The door molex is connected in the front of the door jamb, you will need to make some sort of grommet to fasten the boot to the door......or just pick up the factory door molex.
Kirk R
Old Dec 26, 2008 | 11:34 PM
agoon_911's Avatar
henwon... I have a reason to believe that door has been replaced with a door from a different civic, and whomeven installed it didn't care much about audio... it would help us if you tell us more about your civic...
wat year it was built, if it's a sedan, coupe or hatchback, and if you have a hole on the door...
Old Dec 28, 2008 | 09:18 PM
toner297's Avatar
just make your life easier and run your own wires through the door jam dont forget to loom them up
BrotherAli
Audio / Security / Video
Jun 10, 2016 10:26 AM
eL
18
Dec 19, 2007 02:15 AM
SheHateMe
Nov 3, 2006 07:56 AM
93gsrhatchbrid
Apr 2, 2006 01:52 PM
Turbo'dMex-A-Keen
Mar 5, 2003 08:40 AM
