plz help.......amp switch question?
Old Feb 5, 2005 | 01:21 PM
dabrat8614's Avatar
Default plz help.......amp switch question?
ok i have a universal switch and i want 2 hook it up to make my amp turn on and off how do it do it? it has three prongs on the back of it plz help me hook it up to amp for a tuirn on/off switch
Old Feb 6, 2005 | 08:47 AM
swaytec360's Avatar
Default Re: plz help.......amp switch question? (dabrat8614)
well you dont really need an on off switch you can run it to your power antena lead or any ignition power but 3 prongs one is for 12volt igntion one is for ground and the other you run to your amplifier make sure you dont run your 12v in to constant or if you forget to turn your switch on your amp will be on even if your car is off
Old Feb 6, 2005 | 01:03 PM
fcm's Avatar
fcm
Old Fart
Default Re: plz help.......amp switch question? (swaytec360)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swaytec360 &raquo;</TD></TR><TR><TD CLASS="quote">well you dont really need an on off switch you can run it to your power antena lead or any ignition power but 3 prongs one is for 12volt igntion one is for ground and the other you run to your amplifier make sure you dont run your 12v in to constant or if you forget to turn your switch on your amp will be on even if your car is off</TD></TR></TABLE> Like I asked the last one that gave this advice, what if its a SPDT switch, you would need to know what kind of switch it is before you tell someone to hook one term. to ground and another to 12v ign., that only applies to illuminated switchs. 94
Old Feb 6, 2005 | 01:19 PM
Coop's Avatar
yeah, one of the prongs goes to power, one to ground, and one is a ground for the light in the switch, do you still have the packaging? should tell you wich is wich in there.
Old Feb 7, 2005 | 09:51 AM
TallAssFilipino's Avatar
For what car?
eazy64
Oct 17, 2010 09:09 PM
CBL9
Apr 25, 2009 07:07 PM
dabrat8614
Audio / Security / Video
Feb 6, 2005 12:21 PM
njandrewg
Oct 2, 2004 01:58 PM
HondaGuRu
10
Jul 23, 2003 09:05 AM
