PLEASE HELP ME!!!
My friends and I installed my 99-00 OEM civic fog lights about a week ago and we did this DIY mod to turn on the fog lights with just the parking lights on, and i had one problem with this already and fixed it and now this occured.
https://honda-tech.com/zero...age=1
The first problem that occured was when my parking lights didn't flash but the instrument lights did when i armed & disarmed my alarm but when i turned on the lights manually the parking lights worked and the instruement lights didn't (it was due to the instrument lights fuse blowing), I had changed the tail light fuse to a 10amp fuse like the DIY said to do and my instrument lights fuse kept on blowing when i armed & disamred my alarm with my fog lights in the "ON" position. So I changed the instrument lights fuse to a 10amp fuse and put the tail light fuse back to stock (7.5amp) which solved the problem.
Now, everything has been working fine untill today when the parking lights & instrument lights stoped flashing when i arm & disarm my alarm.
What could possbily be wrong this time? I already checked all the fuses (tail lights & instrument lights) and they were fine, I even put new ones and changed the tail lights fuse back to a 10amp fuse just in case and tested it out but no luck. I have a Clifford RSX 3.5 pager alarm, could i have blown a light fuse for the alarm if there even is one? i'm just hoping that i didn't fry anything.
I TIA to anyone that thinks or can help me with this. i'm just stumped and don't know what do
Modified by JDM B16 EK at 3:37 PM 3/8/2005
Modified by JDM B16 EK at 3:56 PM 3/8/2005
It happen to me to, all you have to do is change your actual alarm fuse. its gonna be a big red 10 amp fuse that u have to go to autozone. u should find the fuse under your dash where your alarm brain is. i just put a 15amp fuse in there and its been working ever since.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EM1 »</TD></TR><TR><TD CLASS="quote">It happen to me to, all you have to do is change your actual alarm fuse. its gonna be a big red 10 amp fuse that u have to go to autozone. u should find the fuse under your dash where your alarm brain is. i just put a 15amp fuse in there and its been working ever since.</TD></TR></TABLE>
I'm not the only one this happend to huh? So there is a seperate fuse for the alarm, and all i have to do is change the 10amp fuse to a 15amp? do you know if this could cause any electrical damage to the componets? thakns for your help btw
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EM1 »</TD></TR><TR><TD CLASS="quote">nothing happened to mine, theres a separate alarm fuse in my viper that i changed to make it work.</TD></TR></TABLE>
okay thanks i will give this a shot and see how it goes & LYK
Modified by JDM B16 EK at 12:22 AM 3/10/2005
B18b Axles
Jun 17, 2012 10:52 PM
