Compustar help
Old Mar 9, 2005 | 12:10 PM
pdiggitydogg's Avatar
Default Compustar help
So I just finished wiring everything up (thanks imola-red and fcm for the post - https://honda-tech.com/zerothread?id=1109351 ), and I cannot get the thing to activate.
I have done the on/off thing correctly: relay clicks once, twice, remote beeps and the lcd flashes all signs...but still nothing happens. Ive done this twice and double checked all connections (12v,grounds). If I can just get the led to turn on to tell me its working I'll call it a victory and go from there (locks mainly, since I know the pins wires are right).
Is there something I'm missing? I mean, it should start working with just power, ground, and the antenna right?
I have 1 remote (lcd), no remote start
I wanted to finish this today
Old Mar 9, 2005 | 01:12 PM
alright, I just figured out that when I do the relay on/off thing the system clicks once after starting and then as soon as I put the batter back into the remote the relay clicks twice, signalling that its exiting the learning mode - before I even get to press the button...
Old Mar 9, 2005 | 01:53 PM
Odessa's Avatar
Default Re: (pdiggitydogg)
The documentation for the remote learning sucks a big one. The most important thing is they forget to tell you, that you have to press button "I" during the learning process...otherwise good luck wasting time and nerves.
Old Mar 9, 2005 | 01:55 PM
So Im supposed to press 1 as soon as I put the battery back in, after the relay clicks once?
Wouldnt that cancel the setup?
Old Mar 9, 2005 | 01:58 PM
Odessa's Avatar
I can't remember when exactly to press button "I", 'cause I've done it like half a year ago, but if I recall correctly, then yeah, after you put in the battery. It won't cancel anything, but it will only make your remote work...finally.
Old Mar 9, 2005 | 04:00 PM
tried that a bunch of times...no go
On a side note:
After I installed it all, I hear a slight grinding when the clutch is not depressed...couldnt be the starter itself could it?
Old Mar 9, 2005 | 06:50 PM
anyone else with something to try before I just take it in for pros to take a look at it...
samx227
May 17, 2014 06:14 PM
hondacoupe05
Dec 29, 2008 08:29 PM
kleen98accord
Audio / Security / Video
15
Aug 25, 2008 12:18 PM
Eg6xCiViCxSi
Jan 20, 2008 02:39 PM
2.3lcivic
Oct 1, 2007 09:34 AM
