Passive locking system....
Old Mar 24, 2007 | 12:41 AM
John 07's Avatar
Default Passive locking system....
So my DEI Avital alarm system is set to Passive lock which means it locks automatically in 30 sec after egnine shut off. Its just very annoying when i get it serviced, put gas in and so on. I hate the fact I have to put it to sleep mode. So my question is how do I make it so that its not on passive lock any more?? Thanks
Old Mar 24, 2007 | 05:41 AM
B18C_EJ8's Avatar
Do you know where your valet switch and installation manual are?
If you cannot answer yes to both of those questions, take it to wherever you had the alarm installed and have them change the programming.
Old Mar 24, 2007 | 08:43 AM
fcm's Avatar
fcm
Old Fart
Default Re: Passive locking system.... (John 07)
What Avital alarm, there are more then 30 of them? 94
Old Mar 24, 2007 | 08:33 PM
John 07's Avatar
I have the avital with 2way pager. Its their only one witht the 2 way pager. I know where the valet switch is but in order for it to work you have to turn the engine on and then off and press the button. It gets anoying when you have to do that every time. So in order to fix this I must get it reprogramed at the place that installed the alarm??
Old Mar 24, 2007 | 08:46 PM
EM2ner's Avatar
Default Re: (John 07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by John 07 &raquo;</TD></TR><TR><TD CLASS="quote">I have the avital with 2way pager. Its their only one witht the 2 way pager. I know where the valet switch is but in order for it to work you have to turn the engine on and then off and press the button. It gets anoying when you have to do that every time. So in order to fix this I must get it reprogramed at the place that installed the alarm??</TD></TR></TABLE>
Yup they have to enter the programing mode with the key on-off cycle. shouldn't take them longer than 5 mins to do it.. Its not really that hard to do
Old Mar 25, 2007 | 08:51 AM
fcm's Avatar
fcm
Old Fart
That sounds like the Avistart 4400, you can change the programming yourself it's easy
1- open drivers door
2- turn ign. on then off
3- press and hold valet/program button until LED flashes once and siren chirps once, then release, [feature menu one]
4- within 10 sec. press and release valet/program switch again, then press and hold it, after a second the LED will flash one time a second, [feature one, passive/active arming]
5- while still holding the valet/program switch press and release the arm/lock button on remote, siren will chirp one time
6- release valet/program switch
Your done, alarm is now in active arming mode. 94
robotech
Audio / Security / Video
Dec 17, 2008 06:18 AM
dad0c402
Aug 12, 2008 09:44 PM
DriveSlowHomie
Oct 26, 2006 03:11 PM
SD_EM1
Jun 27, 2005 01:42 AM
mickey513
Jul 9, 2003 03:45 AM
