Parking Light Output Question
Old Dec 2, 2009 | 09:58 PM
rugimpy's Avatar
Default Parking Light Output Question
Im installing an alarm on a 93 civic dx coupe. I am wondering how I would find out what my parking light output is on my car. I need to know if I should place the jumper on my alarm (viper 350+) to positive or negative and whether or not I need a relay. Thanks.
Old Dec 2, 2009 | 10:06 PM
dohcvtak's Avatar
Default Re: Parking Light Output Question
oops my bad its only - when ur using bb with the relay method fcm is right arg forgot ><
Old Dec 3, 2009 | 05:58 AM
fcm's Avatar
fcm
Old Fart
The park light output is pos.(+) on your 93... http://64.85.6.121/diagrams/printpag...16307&MakeID=3 it can also be found at the park light free pin on the under dash fuse box. 94
Old Dec 3, 2009 | 06:44 AM
rugimpy's Avatar
Alright cool. So no relay is needed. Perfect, that makes things a lot easier.
Old Dec 3, 2009 | 06:49 AM
dohcvtak's Avatar
again my bad haha.. but are u sure? back up battery goes a long way dont underestimate it..
Old Dec 3, 2009 | 09:47 AM
rugimpy's Avatar
Oh, im definately using a backup battery. I dont see how using that would make me need a relay for my parking lights though, would it? It wouldnt change the polarity.
Old Dec 3, 2009 | 11:41 AM
dohcvtak's Avatar
in the big scheme of things u do not want to have the parking lights flash while the small bb is activated thereby increasing the run time of the bb..
Old Dec 3, 2009 | 12:24 PM
rugimpy's Avatar
So you are saying, if someone were to unplug my battery and the alarm were running off the backup battery, it would drain quicker with the parking lights running strictly off the alarm?
Old Dec 3, 2009 | 12:26 PM
rugimpy's Avatar
Would it would be that significant of a loss. I mean would it cut the time from maybe 20 minutes on the battery to maybe 18? Or would it drop it by half? If its just a bit mroe drain, I would rather not deal with an extra relay.
Old Dec 3, 2009 | 02:14 PM
White Smoke's Avatar
i my honda
Global Mod
The backup battery is not going to keep anything going for very long. The parking lights are not as important as a siren, so I would not hook those to the BUB if I were you.
Old Dec 3, 2009 | 03:05 PM
rugimpy's Avatar
Well honestly I only need the alarm to go off for a minute to get to my car. I only take it to work and home, and they cant take it at work, so I just need it to go off long enough at home to get outside. Also, im going to hook my parking lights up to my alarm, so I dont see a way I can have them hooked up to the alarm itself but not the backup battery.
rugimpy's Avatar
If there is a way, Id love to use it, that way I can save my backup battery but I dont know if thats possible.
Old Dec 3, 2009 | 04:32 PM
dohcvtak's Avatar
post 2,5,6,7 already establish that its possible and u still have to ask if it is!? seriously?..
spst (think it was wrxstikiller Desmon where i learned it from )
85= 12V loop to 87 either or..
86= - alarm light wire
87= 12v loop to 85
30= parking light wire
and switch the jumper to negative
correct me if i messed up somewhere..
Old Dec 3, 2009 | 06:36 PM
fcm's Avatar
fcm
Old Fart
Skip the relay and, if you have not already, replace the back-up batt. with a bigger better one, [make sure it is fully charged before connecting] that way you can have both the lights and the siren(s) running long enough for you to get to the car.
It's a pretty good bet a crook is not going to hang around long by car that he can not disable the screaming siren and flashing lights of the alarm system he has triggered.
It's also a good bet a good BUB will outlast the most jacked up crack head or pro. 94
Old Dec 3, 2009 | 07:30 PM
rugimpy's Avatar
Exactly what I was thinking fcm. Thank you. I dont want to mess with a relay. I appreciate your help as always. dohc, thank you for your input as well. I appologize if I came off a bit confused.
The-Kid
May 8, 2020 06:25 PM
WhiteNeko
Jul 10, 2012 03:25 PM
uhhRay
Audio / Security / Video
Mar 21, 2012 06:29 PM
kinick313
Nov 23, 2007 03:01 PM
danielbassil
Jul 24, 2004 06:08 PM
