Paper or Plastic
Old Aug 10, 2001 | 08:14 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Paper or Plastic
On the speaker cones, I know plastic will last a lot longer. But what about sound quality? Is there a difference between paper and plastic?
Old Aug 10, 2001 | 08:51 AM
crux131's Avatar
Default Re: Paper or Plastic (GoLowDrew)
I think most of the woofers available are poly coned for strength and reliability! The stronger cones flex less and create less distortion. A properly designed paper cone would act similar, and a poorly designed poly cone could sound worse.
Now the flex of paper or poly cones will also "color" the sound slightly, that can actually play into a good effect, not all speakers will sound identicle.....meaning you get to pick ones that sound best to you.
__oversea
Welding / Fabrication
Apr 27, 2006 02:55 PM
