How much does size matter?
Old Aug 10, 2001 | 08:17 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Default How much does size matter?
I know I asked about the shape of the box before, so I guess this would be Part II.
Going back to box again. Is there a general rule we can go by.
If the box is slightly bigger or smaller than what the sub manufacture recommend, how would it effect sound quality?
Old Aug 10, 2001 | 09:54 AM
dc24me's Avatar
Default Re: How much does size matter? (GoLowDrew)
If it's a sealed enclosure, it will not be as crucial, since if the volume of the enclosure changes, it will only effect the F3 or 3dB down point of the box, or the point at which the response of the woofer starts to drop or roll off. There is a lot of fudge factor allowed in a sealed box. It will have an effect on how low the speaker can play.
But for a vented or ported enclosure, you pretty much need it to be exact because the port length is determined by the frequency you want to tune it and the volume of the enclosure.
[Modified by dc24me, 10:55 AM 8/10/2001]
Old Aug 10, 2001 | 09:56 AM
Steve's Avatar
smaller then the manufacturer specs would make less area in the box. This would cause higher sound pressure and make the bass tighter.
larger then the specs would make more area in the box. this would cause lower sound pressure and make the bass looser(don't think that's the proper term for it though)
Mind you those are rules for sealed enclosures... I'm not sure how the change when you start to deal with vented enclosures.
civic_tuned
Audio / Security / Video
May 9, 2006 08:26 PM
typeR#0427
Jul 5, 2004 06:19 PM
SoulSurfer
Feb 7, 2004 11:15 PM
shorty0o29
Mar 29, 2003 06:01 AM
xsuperdanx
Jan 23, 2003 12:40 PM
