Ohms
well i have some older CP12 Kickers and they are 8ohms a piece so total of 16ohms and i was wondering if there was any way possible to get it down to 2ohms cuz im at 4 now and was wondering if i could go any lower
In short no, 2 x 8 ohm VC can be wired in parallel for a 4 ohm load, [sounds like you already have them that way] there is no way to get the impedance lower, [unless you add 2 more 8 ohm subs].
94
94
are the SVC or DVC because if they are SVC then your options for wiring are 4 ohms and 16 ohms, obviously you would want 4 ohm which is wiring in parallel
if they are DVC (4 ohms per coil) you can get 1 ohm by wiring ur coils in parallel then wiring the two subs in parallel. (thats 2 ohms per speaker, in parallel =1 ohm)
i do have them wired in parrallel and they are at 4ohms right now and i was wondering about what you said about svc and dvc cuz im not really familier with that please more info and they are wired to a 920 kenwood 2 channel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">SVC = Single Voice Coil
DVC = Dual Voice Coil</TD></TR></TABLE>
ding ding a weiner.
if you look at that link i posted it will give you different wiring options and tell you the impedance each one will give
if your amp is 1 ohm stable in bridged mode then i would wire it how i said before, but i dont think that amp is 1 ohm stable, so your only option is 4 ohm
if your subs really are 8 ohm, its kinda hard to find 8 ohm, are you 100% sure that they are 8 ohm?
ding ding a weiner.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egsedan »</TD></TR><TR><TD CLASS="quote"> its kinda hard to find 8 ohm, </TD></TR></TABLE>
What? your not looking very hard.
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egsedan »</TD></TR><TR><TD CLASS="quote">8 ohm SVC? i been trying to find an 8 inch to use for my pc speakers and cant find one.
a DVC you can get a dual 4 ohm and make it 8</TD></TR></TABLE>
http://www.partsexpress.com
Two pages of them can be found here
nice site,
im not looking very hard.
are those car speakers subs, or home theatre, or both.
before i blew my subs out i would put them in my car, run them, then just bring one inside and use it on my pc since i blew the one in that one as well lol.
anyway, this isnt my thread
/threadjacking
/threadjacking
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">How about a JL Audio 8W0-8 8" 8ohm sub. 94
Do they make one? Do you have one? I'll give you $5 for it!
i am positive they are 8ohms i pulled them outta the box a while ago and on the back it said cp12 then on the left side of the magnet it said 8ohms. and thank you for the help i dont believe that the amp is 1ohm stable
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme »</TD></TR><TR><TD CLASS="quote">A question for some of you.
When you measure a voice coil with an RMS multimeter what is that a measurement of.
I'm not asking because I don't know, I'm asking so others may learn.
you are measuring the DC resistance, not the impedence although both are measured with ohms. do i get a prize?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI »</TD></TR><TR><TD CLASS="quote">
you are measuring the DC resistance, not the impedence although both are measured in the unit of ohms. do i get a prize?</TD></TR></TABLE>
Yes you are correct.
Impedence=Resistance + Reactance
Resistance is the DC component Reactance is the AC component.
An ohm meter passes a small dc current through the speaker to make it's measurement.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">i am positive they are 8ohms i pulled them outta the box a while ago and on the back it said cp12 then on the left side of the magnet it said 8ohms. and thank you for the help i dont believe that the amp is 1ohm stable</TD></TR></TABLE>
then it appears that for now you have to run it at 4 ohm
milo
Audio / Security / Video
Jan 23, 2008 06:52 PM
phayzeone
10
Jan 31, 2007 05:10 PM
