Ohm question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RUBZERK »</TD></TR><TR><TD CLASS="quote">Is a 2 Ohm dvc sub better than a 4 Ohm dvc sub ???
what is the diff ?????</TD></TR></TABLE>
No, the only difference is the impedence. The one right for you would depend on your amplifier. "Generally" speaking a two ohm speaker will allow you to extract more power out of your amplifier. A DVC 2 ohm speaker wired in parallel will make a 1 ohm load to your amplifier.
What amplifier do you intend to use? Do you intend to run it in stereo or mono?
