Normally open or closed
Old Mar 24, 2007 | 08:25 PM
ninjarich2's Avatar
Default Normally open or closed
hey guys, I'm about to do a Clifford arrow 5. What do you guys prefer for the starter kill, normally open or closed?
Old Mar 24, 2007 | 08:31 PM
94_DC4's Avatar
Default Re: Normally open or closed (ninjarich2)
Rest at normally closed.
Old Mar 24, 2007 | 09:18 PM
suspendedHatch's Avatar
I might have covered this in the sticky or it might be planned for my new site. Anyway, there are advantages/disadvantes to each.
Normally closed: this is how shops set it up so that if the alarm fails, it wont strand their customer. This is great for customer service, but not so good for security. If your alarm is disconnected by a thief, then there is no need to bypass the starter circuit because it's NORMALLY CLOSED.
Normally open: this method is more secure because even if power or ground is removed from your alarm, or the control wire to the relay is cut, it's still actively preventing the car from starting. However, in a couple years when your alarm stops working because of the crappy "standard" install, you will have to bypass the starter kill circuit or your car wont run.
Old Mar 24, 2007 | 09:39 PM
nsxxtreme's Avatar
Default Re: Normally open or closed (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">However, in a couple years when your alarm stops working because of the crappy "standard" install, you will have to bypass the starter kill circuit or your car wont run.</TD></TR></TABLE>
Or the natural failure of a relay.
That said I prefer Normally open it offers far more security.
Old Mar 25, 2007 | 11:58 AM
Default Re: Normally open or closed (nsxxtreme)
I've never had a relay go bad on me. But it's a good idea to use Bosch relays for critical things that affect whether your car can run.
The car is fully of OEM relays anyway.
jfoltz99
Jan 26, 2012 11:46 AM
Type XS
Audio / Security / Video
Oct 1, 2006 08:57 AM
aquarius
Jul 15, 2004 07:53 AM
stock97
Dec 18, 2003 11:12 AM
Weston
Jan 30, 2002 04:01 PM
