noob. never put in a cd player before
Old Nov 11, 2006 | 06:53 AM
draperj09's Avatar
Default noob. never put in a cd player before
i just got a jvc cd player and i have seen a lot of people install them just never tried to myself. its a good time to learn. i know how to do everything besides the wiring. basically just match up all the colors, correct? tape up the leftovers? im using a adapter kit its going in my 90 civic. i am just not sure which wire is which
Old Nov 11, 2006 | 07:38 AM
B18C_EJ8's Avatar
Yes, you just match the colors on the two harnesses and plug them in. However, if the radio harness in your car has been cut off, you'll need to connect the wires function to function, NOT color to color... You can get the wiring colors from http://www.installdr.com.
Old Nov 12, 2006 | 03:53 PM
Thizzed Out's Avatar
Default Re: (B18C_EJ8)
umm i'd let some1 who knows how to install the cd player do it..u might burn out something.
Old Nov 12, 2006 | 04:25 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">umm i'd let some1 who knows how to install the cd player do it..u might burn out something.
The worst that could happen is that you blow a fuse... Follow my directions above and you'll be fine.
Old Nov 12, 2006 | 04:28 PM
if this guy install's the cd player correctly ill be amazed..
Modified by thizzed_out_civic at 7:25 PM 11/12/2006
Old Nov 12, 2006 | 04:40 PM
bart2546's Avatar
Default Re: (thizzed_out_civic)
Well hopefully all goes well, but once you know how to install a head unit once, you're golden for any number of others.
Old Nov 12, 2006 | 04:45 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">if this guy install's the cp player correctly ill be amazed..</TD></TR></TABLE>
Says the guy who needed help with clearing his headlights...
https://honda-tech.com/zerothread?id=1754896
And your point in posting? Just to be a dick??? His question is no worse than yours...
Old Nov 12, 2006 | 05:02 PM
bart2546's Avatar
Well if worst comes to worst, hopefully he knows to just hook up all power wires, and then try one set of speaker wires at a time, following the HU's book for the wire diag.
Old Nov 12, 2006 | 05:16 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: (bart2546)
Old Nov 12, 2006 | 06:08 PM
cdx280's Avatar
if the factory wires aren't cut, then using a harness is pretty simple...
yellow - constant 12v
red - ignition
black - ground
grey/grey black - RF
white/white black - LF
purple/purple black - RR
green/green black - LR
blue - remote (used for amps)
blue white - power antenna
orange - illumation
if the factory harness is cut, then i can post the color codes for the factory wires (since they are not the same as what i just listed)
Old Nov 12, 2006 | 06:27 PM
Default Re: (cdx280)
haha i aint being a dick..i dont even know how to install a cd player myself, i left that to some1 who knows
Old Nov 19, 2006 | 12:44 PM
draperj09's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thizzed_out_civic &raquo;</TD></TR><TR><TD CLASS="quote">if this guy install's the cd player correctly ill be amazed..
Modified by thizzed_out_civic at 7:25 PM 11/12/2006</TD></TR></TABLE>
installed. correctly, too...
Old Nov 19, 2006 | 12:54 PM
bart2546's Avatar
Default Re: (ef_dude)
Cool, now you can bump around town and **** off the neighbors.
Old Nov 19, 2006 | 01:32 PM
EBP_SI's Avatar
installing a deck is pretty simple actually. once you know what the wire colors in the car are, its just a matter of connecting the appropriate wire. i find the biggest problem most people have is making proper connections. most of the time they just twist the wires and use electrical tape.
broody
12
Aug 15, 2011 03:56 PM
si_23
Apr 10, 2011 01:56 PM
yeaaaa its slow
Audio / Security / Video
Aug 26, 2004 07:28 PM
Junior Carioca
Feb 28, 2004 05:14 AM
pHaNt0m0o0o
Oct 22, 2001 09:25 AM
