Negative things of having remote start?
Old Feb 20, 2006 | 01:46 PM
dk015's Avatar
Default Negative things of having remote start?
I have an 01 Accord V6 with a Clifford RSX 3.5 alarm, and I just bought the Remote start module (DEI 556U). I was wondering if theres any problems with having remote start, like ignition problems in the furture or anything else. Thank You
Old Feb 20, 2006 | 02:57 PM
phoshizzle88's Avatar
Default Re: Negative things of having remote start? (dk015)
havent had a prob with mine yet had it over a year
Old Feb 20, 2006 | 04:12 PM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
Technically, the alarm is doing the same thing as a key turning in the cylinder. It's temporarily giving +12V to the starter wire. It's the same with your key. If you notice, you turn the key to ACC, then IG, then START, but after the engine starts and you release the key, it pops back into the IG position. By holding it in START position, you're giving +12V positive to your starter wire.. just like what the alarm did.
Besides that, I've seen the keysense unit on the car get messed up and not read any keys. If that happens, and I don't know how it happens, you need to go to the dealer and have them match a set of keys to your key cylinder.
Also, if your car is manual tranny, don't leave it in gear. For obvious reasons ofcourse.
Old Feb 20, 2006 | 04:15 PM
dk015's Avatar
Thanks for your guys' help
Old Feb 21, 2006 | 08:23 PM
incubus's Avatar
u know that the 556u isnt a "remote start module" it is a Transponder box. All it will do is house your transponder key and send the signal to a remote start that hopefully your alarm already has. It is a universal part so u will have to give up one of your keys.
Remote starts are great for cars, the worst thing you can do to a car is drive on a completely cold engine. it preheats the engine for you which will extend the life of your motor. The only real drawback is the fact that it is obviously consuming gas while sitting, but your car gets poor gas mileage if you drive it cold anyway.
Old Feb 21, 2006 | 08:24 PM
incubus's Avatar
Default Re: Negative things of having remote start? (ScareyH22A)
01 accord V6 cant be a manual.
Old Feb 21, 2006 | 09:49 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Negative things of having remote start? (incubus)
The only down side i have had was letting some one see my keys after pressing buttons on the controler, and having them put the car on temp start and not noticing, Car is running when not needed because it starts to keep the inside warm or cool. depending on how I have it set.
Old Feb 22, 2006 | 02:41 PM
R-81DC2's Avatar
Default Re: Negative things of having remote start? (wrx-killer-Sti eater)
With remote start on vehicles with an immobilizer, isn't the key hidden in the black box that connects to the alarm. If so what if a theif finds that black box- he can then start your car the a key? Correct me if im wrong
Old Feb 22, 2006 | 02:55 PM
Default Re: Negative things of having remote start? (R-81DC2)
It depends on the unit being used. some use a second key or you can get a unit that remebers the code of the key.
Old Feb 22, 2006 | 03:19 PM
R-81DC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">It depends on the unit being used. some use a second key or you can get a unit that remebers the code of the key.</TD></TR></TABLE>
neva heard of that unit- u got any links
Old Feb 23, 2006 | 10:21 AM
ScareyH22A's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R-81DC2 &raquo;</TD></TR><TR><TD CLASS="quote">With remote start on vehicles with an immobilizer, isn't the key hidden in the black box that connects to the alarm. If so what if a theif finds that black box- he can then start your car the a key? Correct me if im wrong</TD></TR></TABLE>
I always break off the tip of the key and use the plastic handle w/the embedded chip in it.
Old Feb 23, 2006 | 12:27 PM
R-81DC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScareyH22A &raquo;</TD></TR><TR><TD CLASS="quote">
I always break off the tip of the key and use the plastic handle w/the embedded chip in it.</TD></TR></TABLE>
that's the trick
jfoltz99
Jan 26, 2012 11:46 AM
bmxprodm
Audio / Security / Video
Aug 9, 2011 01:50 PM
speed_bumps_suc
Feb 28, 2010 06:26 PM
miller.91.HB
Dec 15, 2004 03:25 PM
incogNitto
Jul 14, 2002 12:58 AM
