Need port length calculated
Old Aug 13, 2006 | 10:40 AM
nsxxtreme's Avatar
Default Need port length calculated
I know some of you have some cool software out there I need a port length calculated.
I picked up some old 12'' Kicker CompVR's The back of the magnet says C12d Single voice coil 4 ohms. They must be older then 2002 because I cant find the specs for them. IMO they look like just the same kicker comps they have been making for years.
This is the best I could do for specs http://www.kicker.com/06/tech-...l.pdf
I have 1.2CF of air space and I want to use a 3 inch round port. I need the length calculated for I guess 32 HZ sounds good.
Going in my boat til they blow
Thanks in advance!!
Old Aug 13, 2006 | 12:30 PM
8520's Avatar
Default Re: Need port length calculated (nsxxtreme)
You tried winisd?
Old Aug 13, 2006 | 12:34 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
I have a killer program but it on my shops computer, And I have to set it up. To really get the right box Your gonna have to find the exact specs on the sub. I tried calling some of my other friends that are in the industry and they say thoses speakers are oldddddddd. lol. Here is a site that can get you on your way. I think your cf is to small for a port. But thats me. But here play with this to I can set up my computer later. http://www.carstereo.com/help/Articles.cfm?id=31
Old Aug 13, 2006 | 12:45 PM
02 accord's Avatar
Default Re: Need port length calculated (wrx-killer-Sti eater)
I'd say start here: http://www.diysubwoofers.org/measure.htm. Measure the t/s params and then plug them into winisd to get your port length.
The port length depends on the t/s of the speaker, and not just on the box volume and port size; I don't see how the previous link will get you anywhere near your target tuning frequency, when it doesn't even consider what speaker you have.
Old Aug 13, 2006 | 12:48 PM
nsxxtreme's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">I have a killer program but it on my shops computer, And I have to set it up. To really get the right box Your gonna have to find the exact specs on the sub. I tried calling some of my other friends that are in the industry and they say thoses speakers are oldddddddd. lol. Here is a site that can get you on your way. I think your cf is to small for a port. But thats me. But here play with this to I can set up my computer later. http://www.carstereo.com/help/Articles.cfm?id=31 </TD></TR></TABLE>
I picked up 2 12's for $60. So ya they are old but plastic so an ocasional hit with water wont hurt them. Plus $60 I dont care if they get F up. Website says about 13" I'll try that. I'm not concerned about getting it exact. Once the boat throttles up you can bearly hear it anyway.
Old Aug 13, 2006 | 10:20 PM
nsxxtreme's Avatar
If anyone can find the specs on the speaker that would be great.
I ended up putting two, 2inch ports 12 inches long for each box.
If someone can punch that in that would be great also.
Old Aug 17, 2006 | 10:17 AM
audioroach's Avatar
Default Re: Need port length calculated (a_s_ol_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a_s_ol_ &raquo;</TD></TR><TR><TD CLASS="quote">You tried winisd?</TD></TR></TABLE>
I 2nd this program as well...use the pro version. Very helpfull for what it does.
I'll check my Kicker info when I get home...I may be able to get T/S and a box size for ya.
Old Aug 17, 2006 | 11:45 AM
nsxxtreme's Avatar
Default Re: Need port length calculated (audioroach)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by audioroach &raquo;</TD></TR><TR><TD CLASS="quote">
I'll check my Kicker info when I get home...I may be able to get T/S and a box size for ya.</TD></TR></TABLE>
Box is already built, I'm still interested in what the program comes up with if anyone has time.
I built the box to fit the boat everything else comes second. The box is a little over 1.1 CF. I put two 2" ports 12" long in each box. Haven't mounted the speaker yet because I am still rubber coating the box.
Old Aug 17, 2006 | 12:04 PM
8520's Avatar
Any reason you're not resin coating?
Old Aug 17, 2006 | 12:31 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a_s_ol_ &raquo;</TD></TR><TR><TD CLASS="quote">Any reason you're not resin coating?</TD></TR></TABLE> Ditto that, I use fiberglass resin on all my boat box's, [have not found anything that works better] BTW if the box is ported don't forget the inside of the box, espesally the edge of the mounting hole cutout, also I never use a ported box if the boat is used in the salt-chuck, salt air will destroy the speaker terminals and tinsel leads, even on marine speakers 94
Old Aug 17, 2006 | 01:31 PM
nsxxtreme's Avatar
Lazy
I just painted it with snow roof. Suppossedly stretches 350%.
If it doesn't work I'll strip it and go with the resin.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> BTW if the box is ported don't forget the inside of the box, espesally the edge of the mounting hole cutout, also I never use a ported box if the boat is used in the salt-chuck, salt air will destroy the speaker terminals and tinsel leads, even on marine speakers 94</TD></TR></TABLE>
If I am ever in salt water these speakers are the last of my worries. I haven't done the inside I'll take my chances. The port is firing forward and its up of the floor. These will go in the back of the boat under the seats.
Built B16A
Audio / Security / Video
17
Dec 18, 2008 02:21 AM
shyboy817
20
Aug 19, 2006 04:46 PM
Radyjr
Nov 24, 2004 08:53 AM
Hcivic88
Sep 5, 2003 05:25 PM
Torridcivic
Jun 8, 2003 05:18 PM
