need help calculating port
Old Sep 4, 2003 | 06:42 PM
Hcivic88's Avatar
Default need help calculating port
I have to figure out what size I have to make my ports. I have two 10" rockford forgate punch z's. According to fosgates specs, the bo volume can be anywhere between .75cu/ft and 1.75 cu/ft. And with my dimensions (32" by 12" by 12") I have calculated it to being 2.5cu/ft for the two after subtracting the displacement of both subs. Although I think I'm going to be splitting the two subs into their own enclosures, so putting in a sealed wall, which would then make it two 1.3cu/ft enclosures.
Does this all sound alright so far?
anyways, I have no idea what size I have to make my ports. RF says that the port should be 3" wide by 13 1/4" long for a 1.0cu/ft enclosure. I'd like to turn it somewhere around 35hz since that is whats recommended
what are my options here?
thanks everyone
Old Sep 5, 2003 | 08:26 AM
Hcivic88's Avatar
Default Re: need help calculating port (Hcivic88)
somebody mu st know or know where i can find out.. i tried searching but didnt find anything
Old Sep 5, 2003 | 09:25 AM
t0p_sh0tta's Avatar
http://www.jlaudio.com/tutorials/ports/index.html
Old Sep 5, 2003 | 10:58 AM
vteg's Avatar
New User
First of all download winisd if you want to start calculating port volumes.
For a dual sub setup it is easier to common chamber if you are using slot ports. The recommendation from rf is probably a 3 inch round port. I am not going to check the numbers, but from boxes I have built with round ports that sounds like a mid 30's tuning at 1 cube.
Old Sep 5, 2003 | 03:51 PM
Hcivic88's Avatar
Default Re: need help calculating port (vteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tOp shOtta &raquo;</TD></TR><TR><TD CLASS="quote">http://www.jlaudio.com/tutorials/ports/index.html</TD></TR></TABLE>
I've already read this site before, although I just get confused reading it, lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteg &raquo;</TD></TR><TR><TD CLASS="quote">
For a dual sub setup it is easier to common chamber if you are using slot ports. The recommendation from rf is probably a 3 inch round port. I am not going to check the numbers, but from boxes I have built with round ports that sounds like a mid 30's tuning at 1 cube.</TD></TR></TABLE>
I think i'm going to be using round ports for this setup. and yeah, rf does recommend a 3" in diamerter port. Although they recommend 13 1/4" long ports, although my bo is only 12" in depth, so they just wont fit. I was just wondering if maybe just making the port 10" long would make that much of a difference?? Or if there was some other way I will have to do this(ie. using elbows so I can make the port 13 1.4" long)
Old Sep 5, 2003 | 05:25 PM
vteg's Avatar
New User
You will need to use winisd or some other program to calculate the tuning. Take the box internal volume. Subtract woofer displacement (.1 cube is a good assumption for a 12), and port volume. That will give you the box volume. Then you calculate the tuning frequency off that volume with a 3 inch round port at 10 inches.
joelmatt89
Audio / Security / Video
11
Jun 5, 2009 12:55 PM
HYREV2NR
21
Jul 21, 2008 05:41 PM
nsxxtreme
10
Aug 17, 2006 01:31 PM
stock97
Jun 28, 2005 04:48 PM
GroundZer0 336
Mar 9, 2003 05:54 AM
