Need low power consumption relay
Old May 9, 2002 | 11:21 AM
brinks's Avatar
Default Need low power consumption relay
I Need a low power consumption relay for some upcoming security mods. Something that wont drain the battery when left in a closed position with the car off. Anyone know where to get one? radio shack?
Old May 9, 2002 | 01:16 PM
ME's Avatar
ME
Default Re: Need low power consumption relay (brinks)
What exactly is it going to be used for?
Old May 9, 2002 | 04:36 PM
brinks's Avatar
Default Re: Need low power consumption relay (ME)
Need one for a starter kill and another for a fuel kill. The one I have on the starter currently draws too much power. Will drain the battery if left for a week or 2. After doing some research, I think a switch will suffice for the other stuff, (sensors) the current draw is so low.
Old May 10, 2002 | 06:34 AM
ME's Avatar
ME
Do you have an alarm?
Old May 11, 2002 | 04:39 PM
boyracer's Avatar
I think I know. But I really don't
brinks dont worry
any regular spdt relay will draw very little (almost no) current in a normally closed position
just go to your local stereo shop and buy a relay. bosch or potter & brumfield are preferred. i bet if you want theyll wire them for ya for just a coupla bucks.
expect to pay $2-5 for a relay.
Old May 13, 2002 | 11:33 PM
brinks's Avatar
Default Re: Need low power consumption relay (Teken)
the relay is in this mode because it is also operating an led indicator to show that it is active. All 5 terminals are being used for this setup. (part of the hoodlock setup) When coil power is connected, the light comes on and the starter is disconnected. I suppose this could be accomplished with 2 relays though and could allow the relay to be normally closed. Actually, if a thief did manage to break the hoodlock and find the relay and removed it, the connection would be totally broken and the car would not start. It would require some minor rewiring. Easy to do but not so easy if you dont know how its wired. Regardles, it is not my only line of defense. Thanks 4 the concern though, yopur asistance is always appreciated.
ekhatchey
Audio / Security / Video
Sep 6, 2011 12:18 PM
gunmetalteg1
45
Sep 30, 2009 07:20 PM
8520
15
Sep 8, 2008 12:14 AM
2.3lcivic
Oct 1, 2007 09:34 AM
powerfulperformance
Oct 11, 2003 04:36 PM
