need Ideas for S2000 stereo modification.
Old May 21, 2001 | 08:22 PM
FULLTHROTTLE's Avatar
Default need Ideas for S2000 stereo modification.
I am trying to put together a sound system using the factory instrument panel controls, has anyone ever Installed an aftermarket deck and wired the control panel to work? if so info would be helpfyl. (which deck is best)
also I need fresh ideas for subs in the trunk area, and how to port them into passenger compartment. any pics or ideas will be appreciated. Thanks in advance.
Old May 22, 2001 | 03:26 AM
HondaDriver4Life's Avatar
Default Re: need Ideas for S2000 stereo modification. (FULLTHROTTLE)
This would be a fairly difficult task. You'd have to fine someone who has some sort of electrical engineering background in order to figure how Honda's controls can interface with an aftermarket unit.
The easiest radios to work with are the ones with remote control inputs (i.e. many Sony models have an input for their joystick). An engineer or someone with similar knowledge might be able take the joystick apart and figure out how to interface with the factory controls.
If you want to talk to a manufacturer who specializes in this line of work...contact Soundgate via http://www.soundgate.com. They might be able to give you some useful information. Who knows...they might be developing an interface for Hondas as we speak.
Old May 27, 2001 | 12:43 AM
Mr_Shide's Avatar
New User
Default Re: need Ideas for S2000 stereo modification. (HondaDriver4Life)
HondaDriver4Life has good advice. Just call around local auto audio shops and see if you can find one who could do it. From there, learn their reputation, and if it's all good, you're set!
Old May 27, 2001 | 10:15 AM
g4b17's Avatar
New User
Default Re: need Ideas for S2000 stereo modification. (Mr_Shide)
check this out, it might get some ideas from it.http://abmarine.hypermart.net/admin/custom2.htm
as for using the factory controls, some companys started to make interfaces for aftermarket decks. i have not seen one for a s2000 yet but you can get one for just about everything else. they range from about $100 to about $250cdn.
Old May 31, 2001 | 10:22 PM
dc24me's Avatar
If you want to retain the factory radio controls, you can try contacting Soundgate and see if they have and adapter. In the past I've found they are designed only for use with Sony products connected throught the wired remote port. I don't know about you, but I think the Sony headunits are pretty hideous looking, except for the C90. Or you can find someone who is experienced electronics to take dissect a wiresless remote and tap into the existing radio controlls.
As for a subwoofer system, if there is really no way for the bass to penetrate the cabin area from the trunk because it's sealed like an Z3, then build a small fibreglass enclosure molded in the passenger side footwell holding a single 8" subwoofer.
Rumor has it that JL Audio may release a Stealthbox for the S2000 eventually.
[Modified by dc24me, 11:23 PM 5/31/2001]
Old Jun 6, 2001 | 12:50 PM
Rob Dizzle's Avatar
Default Re: need Ideas for S2000 stereo modification. (dc24me)
go to http://www.s2000online.com/forums/index.php
they have all the info for ya
square_1
Honda S2000
Sep 25, 2011 07:37 PM
GSRkrod
Honda S2000
20
Aug 26, 2009 07:17 AM
skastr@s
Honda S2000
Aug 29, 2004 07:05 PM
s2k maniac
Audio / Security / Video
Jul 28, 2004 07:14 PM
Phaze2 Mike
Honda S2000
Jul 3, 2003 06:51 AM
