need a HO alternator fast!
Old Jun 14, 2005 | 01:35 PM
tweekerz's Avatar
Default need a HO alternator fast!
Its taken me 4 yrs & 66k miles & 1.5kws to officially destroy my oem alternator. I need suggestions for an 01 dc2 gsr alternator that will power a system no less than 2000 watts. Any suggestions? Thanks.
Old Jun 14, 2005 | 08:13 PM
ap716's Avatar
Default Re: need a HO alternator fast! (tweekerz)
have u thought about getting that alternator rebuilt with a higher output?
Old Jun 15, 2005 | 06:03 AM
tweekerz's Avatar
Default Re: need a HO alternator fast! (ap716)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ap716 &raquo;</TD></TR><TR><TD CLASS="quote">have u thought about getting that alternator rebuilt with a higher output?</TD></TR></TABLE>
Who can do that sort of job? Is it reliable?
Modified by tweekerz at 7:31 AM 6/15/2005
Old Jun 15, 2005 | 06:36 AM
fcm's Avatar
fcm
Old Fart
Check at your local alt. shops, they can tell you how much bigger, [more output] the stock alt. can be rewound to, it's about 10%, maybe a little more, it's limited by the case size, they will also have "bigger" alt. in stock, don't forget an amp that is 1000 watts RMS with 50% efficiency draws about 160A at peak output, [not all the time, probably averages less then half of that, depends on how loud you play it] your going to need a 200A or bigger alt., if you want it to keep up with a 2000 watt system 94
Old Jun 15, 2005 | 07:52 AM
tweekerz's Avatar
Default Re: need a HO alternator fast! (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Check at your local alt. shops, they can tell you how much bigger, [more output] the stock alt. can be rewound to, it's about 10%, maybe a little more, it's limited by the case size, they will also have "bigger" alt. in stock, don't forget an amp that is 1000 watts RMS with 50% efficiency draws about 160A at peak output, [not all the time, probably averages less then half of that, depends on how loud you play it] your going to need a 200A or bigger alt., if you want it to keep up with a 2000 watt system 94</TD></TR></TABLE>
i figured that all along, with the 200amp+ alts. does anyone have experience, or recomendations of alternators with this capacity?
Old Jun 15, 2005 | 09:00 AM
Phat_Jax's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweekerz &raquo;</TD></TR><TR><TD CLASS="quote">i figured that all along, with the 200amp+ alts. does anyone have experience, or recomendations of alternators with this capacity?</TD></TR></TABLE>
Ohio Generator. Top notch quality, build and output. Great guys and warranty as well, they take care of their customers and have been in the business for a long time now.
Old Jun 16, 2005 | 07:32 AM
sopiwnykg's Avatar
Just received my alternator from alterstart in the mail. Looks mighty nice. Won't be installed for about 2 weeks but, they cleaned it up real nice, re-built it to 150 A and they also give a test sheet with it showing the amount of amps produced at the rpm intervals.
Old Jun 16, 2005 | 09:55 PM
b-power's Avatar
Default Re: need a HO alternator fast! (sopiwnykg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sopiwnykg &raquo;</TD></TR><TR><TD CLASS="quote">Just received my alternator from alterstart in the mail. Looks mighty nice. Won't be installed for about 2 weeks but, they cleaned it up real nice, re-built it to 150 A and they also give a test sheet with it showing the amount of amps produced at the rpm intervals.</TD></TR></TABLE>
How much did it set you back?
Old Jun 16, 2005 | 10:44 PM
sopiwnykg's Avatar
$259 USD shipped up to Canada.
tim_r95
Jan 27, 2015 08:02 AM
Bulli Kid
Audio / Security / Video
Aug 10, 2007 05:04 PM
draperj09
Sep 26, 2006 12:34 PM
cannon_man
Jun 17, 2002 05:50 PM
