Need Help Wiring EDFC Controller
Old Apr 30, 2005 | 10:00 AM
motion's Avatar
Default Need Help Wiring EDFC Controller
The instructions says I need to tap into the all time power supply wire (yellow), accessory power supply wire (red), and illumination power suplly wire (green) to power my controller. Where exactly can I find the wires to connect these to? I know a little about electronics but I don't know exactly what wires (colors) I need to tap into. I thought posting in this forum would give me better answers since you guys deal with electronics all the time. Any help?
Here's the install instructions..
http://www.tein.com/ti/inst/edfcu.pdf
Old Apr 30, 2005 | 04:21 PM
rjr162's Avatar
Default Re: Need Help Wiring EDFC Controller (motion)
you could always tag the wires behind the radio.. you'll find all 3 there.. or down in the steering column
Old Apr 30, 2005 | 06:22 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motion &raquo;</TD></TR><TR><TD CLASS="quote">The instructions says I need to tap into the all time power supply wire (yellow), accessory power supply wire (red), and illumination power suplly wire (green) to power my controller. Where exactly can I find the wires to connect these to? I know a little about electronics but I don't know exactly what wires (colors) I need to tap into. I thought posting in this forum would give me better answers since you guys deal with electronics all the time. Any help?
http://www.tein.com/ti/inst/edfcu.pdf</TD></TR></TABLE>Depending on the year of your Honda/Acura, you will find all 3 of them and a 2nd ign. , [no power when cranking motor to start] at the in car fusebox, they are male spade term. , [freepins] a male spade .250 term., [same size as most sub speaker term. or pos. (+) term. of any speaker] set into the fusebox. all you need, you can also find a good ground around the fusebox 94
Old May 1, 2005 | 07:07 PM
motion's Avatar
Default Re: Need Help Wiring EDFC Controller (fcm)
Thanks for the replies. Do you guys know what color the wires are for these? I just recently had a alarmed installed and most of the wires under the dash are taped up. I was gonna have my installer wire it up for me but he was busy. I searched but came up with nothing. All I need is a good write up with pics and I'll be set.
Old May 2, 2005 | 02:00 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motion &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the replies. Do you guys know what color the wires are for these? I just recently had a alarmed installed and most of the wires under the dash are taped up. I was gonna have my installer wire it up for me but he was busy. I searched but came up with nothing. All I need is a good write up with pics and I'll be set.</TD></TR></TABLE> There are no colors. they are "freepins", [terminals] right on the fusebox 94
Old May 2, 2005 | 02:13 PM
motion's Avatar
Ohhh ok I get it now.. I'll check them out. Thanks
91-ef-hatch
Sep 21, 2007 06:35 PM
Muckman
Audio / Security / Video
21
Jul 9, 2004 08:51 AM
crxaddikt
16
Oct 23, 2003 05:43 AM
Liquidgsr
May 18, 2003 03:25 PM
