Need help rather quickly, going insane.
Old May 20, 2004 | 02:27 PM
sykotic's Avatar
Default Need help rather quickly, going insane.
Guys ok, I got my license back today, I got my car repainted while it was suspended and got it back and stored it in a garage, when I took to the body shop everything was working just fine and I just took everything including the face plate out of the car. I got it back and stored it.
Today I drove it to school cause my license got unsuspended today and the CD player will NOT come on, and the clock doesnt work. All the underdash fuses and the ones under the hood are fine, none are blown. My whole climate control unit works, the lights and stuff, the cigarette lighter works, the sunroof works, everything works except for my cd player and clock. I took the cd player out, my interior is in pieces as I type this. I took my stock tape player and hooked it up and it works fine, wtf?! I hooked up my subharness for the cd player and used a voltmeter to test the constant wire when it came through the harness, where it plugs into the cd player, 1.40V? shouldnt it be 12V? I tested it at the main plug before my subharness and the same thing, 1.40V. I tested the SWITCHING power and it works fine, switchs between about 13V and 8V, I used several grounds for these tests. I believe it should be a 12V constant shouldnt it? Why is it only 1.40V? What could be causing the clock not work?!
The only thing the body shop did was remove my rear interior pieces, none of the door panels or dash... the battery kept going dead and they would have to recharge it a bunch of times in the shop and everytime they did the alarm would go off, the first couple times it went off they disconnected the battery instead of using the key to do it. I really hope it isnt my cd player, it is brand new, the fuse is still fine on it. It is a Alpine CDA-9815, I have a 95 Integra LS.
Someone please try to help me, i'm going nuts here... I am open to any and all suggestions!
Old May 20, 2004 | 03:32 PM
G3NR8's Avatar
Default Re: Need help rather quickly, going insane. (sykotic)
I dunno man....Did you individually run through each fuse with a test light? Sounds like a blown fuse, but you said they were fine. Maybe something came unplugged??? If you wanna make sure your headunit is ok, just connect your yellow constant power wire to the red wire. The radio will power up, but won't retain memory but at least you'll know if it works or not.....
georgelb's Avatar
I would test the fuses again, using a multi-meter instead of just looking at them...if that is what you did.
Old May 20, 2004 | 03:43 PM
sykotic's Avatar
Got it, a guy in the integra section named IN VTEC helped me out. It was a 7.5A fuse called "Back Up".
Old May 20, 2004 | 10:04 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: (sykotic)
Yeah, always check ALL of your fuses. You never know which systems in your car run together or what all of the fuse names are referring to.
Old May 20, 2004 | 11:47 PM
georgelb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sykotic &raquo;</TD></TR><TR><TD CLASS="quote">Got it, a guy in the integra section named IN VTEC helped me out. It was a 7.5A fuse called "Back Up".</TD></TR></TABLE>
That one is usually the culprit, but since you said you checked them all I just suggested using the meter. It is usually faster to just use the meter anyway since you just test the tabs on top and do not have to remove the fuse.
Dennis Melnyk
Mar 15, 2019 08:57 PM
checko
Sep 29, 2011 03:33 PM
BadEH2
Oct 25, 2004 05:37 PM
sykotic
May 20, 2004 04:39 PM
