Need Help with Lights...Pronto!!!!
Old Apr 28, 2005 | 09:54 AM
Datflypapito's Avatar
Default Need Help with Lights...Pronto!!!!
I seem to be having a problem with my parking lights...They just stay on for no reason...I put the Gsr dash and cluster in and everything is workin fyne except the head lights and winshield wiper... doesn't even matter if i turn the signal cuz the parking lights stay on....one of my friends said it prolly has something to do with the alarm and someone else said it might be a bad ground wire...I did removed the alarm though...Someone help me please... This problem isn't allowing me to drive during the night
BTW: I have a 92 Cx hatchback if that helps
Old Apr 29, 2005 | 10:29 PM
North_Texas's Avatar
Default Re: Need Help with Lights...Pronto!!!! (Datflypapito)
Always check your fuses first. Post more if that's not the problem.
Old Apr 30, 2005 | 07:53 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Datflypapito &raquo;</TD></TR><TR><TD CLASS="quote">I seem to be having a problem with my parking lights...They just stay on for no reason...I put the Gsr dash and cluster in and everything is workin fyne except the head lights and winshield wiper... doesn't even matter if i turn the signal cuz the parking lights stay on....one of my friends said it prolly has something to do with the alarm and someone else said it might be a bad ground wire...I did removed the alarm though...Someone help me please... This problem isn't allowing me to drive during the night
BTW: I have a 92 Cx hatchback if that helps</TD></TR></TABLE>It sounds like the parklights are getting power from someplace other then the light switch, have you tried pulling the parklight fuse? Do they go out or do they stay on? 94
Old May 2, 2005 | 10:49 AM
Default Re: Need Help with Lights...Pronto!!!! (fcm)
Fuses are good...i tried that like a few minutes ago...I have no clue where its getting power from.... Any other options?
Old May 2, 2005 | 01:52 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Datflypapito &raquo;</TD></TR><TR><TD CLASS="quote">Fuses are good...i tried that like a few minutes ago...I have no clue where its getting power from.... Any other options?</TD></TR></TABLE>You say you "tried that" does that mean you pulled the fuse? If so, did the lights stay on or go out? There lots of places in the dash that the parklights can get power from, one place is at the radio harness, if you have installed an aftermarket HU and somehow connectedthe radios constant power with the illum. wire, the lights would stay on. if someone asks you to try something and tell you what happens, you need to try it, then post what happens I still don't know if the lights go out , also, are the lights on whenever the batt. is hooked up? and what is wrong with the headlights, and the wipers do they stay on also, or do they just not work?
I would recheck all the connections, all the plugs and grounds from the dash and cluster swap. and make sure you have not "pinched" a wire bundle someplace, [another place the parklights can get power] a "short" is to ground a "cross" is just to another wire if you "cross" any parklight or dashlight wire to a 12v+ wire, the lights will stay on. Try this, [and let me know] with the lights on, turn the dimmer control, does it dim the dashlights? Does it dim the parklights? [ with light switch off] Is there any change when you turn the light switch on to park or all the way to head lights? 94
Old May 2, 2005 | 04:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">You say you "tried that" does that mean you pulled the fuse? If so, did the lights stay on or go out? There lots of places in the dash that the parklights can get power from, one place is at the radio harness, if you have installed an aftermarket HU and somehow connectedthe radios constant power with the illum. wire, the lights would stay on. if someone asks you to try something and tell you what happens, you need to try it, then post what happens I still don't know if the lights go out , also, are the lights on whenever the batt. is hooked up? and what is wrong with the headlights, and the wipers do they stay on also, or do they just not work?
I would recheck all the connections, all the plugs and grounds from the dash and cluster swap. and make sure you have not "pinched" a wire bundle someplace, [another place the parklights can get power] a "short" is to ground a "cross" is just to another wire if you "cross" any parklight or dashlight wire to a 12v+ wire, the lights will stay on. Try this, [and let me know] with the lights on, turn the dimmer control, does it dim the dashlights? Does it dim the parklights? [ with light switch off] Is there any change when you turn the light switch on to park or all the way to head lights? 94</TD></TR></TABLE>
Personally this happened to me. I ended pulling like 4-5 fuses just for my ******* dash lights to stay on. If not that like fcm said connection problem. Post some pictures to help out with your situation on where you think the problem extist.
Old May 2, 2005 | 06:48 PM
Bonez21's Avatar
Default Re: Need Help with Lights...Pronto!!!! (H0LLiST3R)
TRUST ME you guys don't want to see any pictures of all those wires
good luck J-P my shyts bogging again ha!!!!
Old May 3, 2005 | 08:41 PM
Default Re: Need Help with Lights...Pronto!!!! (Bonez21)
Well i just wired up the radio and the clock...thats works fyne...Well from what i've done...I've unplugged the fuse and the lights turn off when the fuse is not plugged in...Also the radio turns off when the fuse for the lights is not plugged in...umm the windshield wipers only go on if i push the clicker down...but when i turn the clicker, it doesn't turn on, neither does the light clicker... So yea i've done what u've guys asked...no luck so far...Any other suggestions fellas?
Old May 3, 2005 | 09:02 PM
**** I can't think of anything else. My problems were always bad connections, wiring bad or bad fuses. What about the relay? Is there a relay for the lights or whatever you need. Check the booklet for Honda. Cars suck sometimes.
Old May 3, 2005 | 09:05 PM
Sorry didn't feel like editing my post. But I placed this here so could read it. Umm post this link in the EG+ Forum area. Your answer will get answered pretty fast. Also, I have my Chilton's book in my lap for Honda 84-95 but can't figure out what you really need to know.
Old May 3, 2005 | 09:09 PM
From what I can see and what my boy is telling me...the lights are getting power from the radio since the radio turns off when the light fuse is removed...just dont kno how to fix the situation....
Old May 3, 2005 | 09:26 PM
Oh, **** it is a connection problem. That's something you and your friend will have to figure out. My radio is powered my fog lights. Vice versa. Just **** around with the radio like grounding it in a different place or something like that. But like I said post in the EG+ Forum section. I'm sorry that I can't be that helpful. My problem is similar but I know what's up with it. I had to reground my CD player once before but I forget the reason I had to.
Old May 4, 2005 | 12:50 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Datflypapito &raquo;</TD></TR><TR><TD CLASS="quote">Well i just wired up the radio and the clock...thats works fyne...Well from what i've done...I've unplugged the fuse and the lights turn off when the fuse is not plugged in...Also the radio turns off when the fuse for the lights is not plugged in...umm the windshield wipers only go on if i push the clicker down...but when i turn the clicker, it doesn't turn on, neither does the light clicker... So yea i've done what u've guys asked...no luck so far...Any other suggestions fellas?</TD></TR></TABLE>The radio should not turn off when you pull the parklight fuse, I would pull the radio, and check the wireing, what kind of radio? and if it's an aftermarket one, did you use an adpt. harness?
also I would check the wireing at the steering colum, [wireing for the lights and wiper switchs]P 94
Old May 4, 2005 | 04:25 PM
alright im a check the wiring on the radio....Its a Pioner Premieer DEH-P640 and yea i used a harness...i'll get back to you when i check the wiring out...
Old May 4, 2005 | 06:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Datflypapito &raquo;</TD></TR><TR><TD CLASS="quote">alright im a check the wiring on the radio....Its a Pioner Premieer DEH-P640 and yea i used a harness...i'll get back to you when i check the wiring out...</TD></TR></TABLE>
Also, check the groundning like said before. I just asked my friend what the problem on my Kenwood b4 and he said it was a bad grounding and connection problem.
Old May 5, 2005 | 07:32 PM
i checked the grounding wire for the radio...no luck there, but im pretty sure it has something to do with the wiring somewhere...im a just find me someone good with wiring around the neighborhood to check it out...thanx for everything fellas
Old May 6, 2005 | 04:37 AM
No prob. if I helped any.
Old May 6, 2005 | 06:13 AM
yea u were more then helpful... good looks
Old May 6, 2005 | 06:28 AM
Commiecircusbear
Jan 29, 2008 01:10 PM
skateboard c
Audio / Security / Video
Jun 6, 2007 12:13 PM
00EK
Feb 17, 2002 08:50 PM
