Need help! Install 810i6
Old Jan 26, 2013 | 09:22 AM
SlvrJdm's Avatar
Default Need help! Install 810i6
Hi there i have a old security that is carbine 3000 but the 810i6 i just brought seem to be more wiring and different. Can anyone guide me on how to install it properly
Old Jan 26, 2013 | 01:45 PM
fcm's Avatar
fcm
Old Fart
Default Re: Need help! Install 810i6
Did it not come with an install guide/wiring guide? 94
Old Jan 26, 2013 | 09:11 PM
SlvrJdm's Avatar
it didn't came with it. Can you help me?
Old Jan 27, 2013 | 05:29 PM
fcm's Avatar
fcm
Old Fart
What is the exact model number?
810i6 does not come up on their site... http://dealers.magnadyne.com/index.c...&Web_CatID=107
The only manual @ 12V.com is the Plus3000. 94
Old Jan 27, 2013 | 06:49 PM
SlvrJdm's Avatar
it called crime guard keyless entry and securitiy 810i6 and it is made by omega
Old Jan 28, 2013 | 06:41 AM
fcm's Avatar
fcm
Old Fart
http://www.caralarm.com/manuals-inst...uard/810i6.pdf 94
Old Jan 28, 2013 | 09:59 AM
SlvrJdm's Avatar
Thank. All right i just look at the cord and yet im confused. The only wire similar is the red and red white on 810i6. Can you help me with other wires. The siren wire is the brown one
Old Jan 28, 2013 | 10:57 AM
fcm's Avatar
fcm
Old Fart
Remove all the wiring for the Carbine alarm and connect up the wiring from your new OMAGA 810i6 to the cars wiring.
You should not be using any of the Carbine alarm wiring, or it's siren.
What is the MM&Y of the car the alarm is going into? 94
Old Jan 28, 2013 | 11:02 AM
SlvrJdm's Avatar
All right i just took out the wiring. I got red and red/white wire hook up to the white wire and brown wire i hook up the siren but the siren have red and black. Do i twist it and put it in brown wire?
Old Jan 28, 2013 | 11:04 AM
SlvrJdm's Avatar
I have no idea what other wire do. I have picture of it on my iphone but i cant find a way to upload on the forum
Old Jan 28, 2013 | 11:37 AM
thatcivic96's Avatar
Did you remove the old siren too? You need to remove every single component of the old alarm. If it is not something you are confident in doing, do not do it. Too much to screw up too easily.
Old Jan 28, 2013 | 01:22 PM
SlvrJdm's Avatar
Yeah i open my dash up and remove every single wire out. Now i just need to help on putting the new alarm since there more wire then the old unit
Old Jan 28, 2013 | 06:25 PM
Look at the manual that was linked before, print it. Bring up OEM wiring diagram for your car, print it. Make a list of what wires go where, and correctly connect them together. However like I stated before, if you do NOT know what you are doing do NOT attempt this, you could mess up your ignition.
Old Jan 28, 2013 | 08:02 PM
SlvrJdm's Avatar
I don't think the car ignition will be dead unless i add more new wire. What im trying to do is plug all the new wire into the old one. But the thing is when i read there alot of wiring from the new wire completely different then the old one.I'm just trying to match the new wire to the existing one that all. Again i just need help with matching wire.
Old Jan 28, 2013 | 08:04 PM
I understand what you are saying, but I cannot sit here and tell you what color goes to what color... the manual was provided in PDF for you... now you need to find out the OEM wire harness colors you need to go to.
Old Jan 28, 2013 | 08:22 PM
SlvrJdm's Avatar
can you at least tell me what i don't need on the new wiring?
Old Jan 28, 2013 | 08:23 PM
SlvrJdm's Avatar
do i need the remote start satellite relay?
Old Jan 28, 2013 | 08:46 PM
Is it a 5 speed? or Auto?
Old Jan 29, 2013 | 04:24 AM
SlvrJdm's Avatar
auto
Old Jan 29, 2013 | 06:24 AM
fcm's Avatar
fcm
Old Fart
Still waiting for MM&Y of your car????
Without it, there is not much I can help you with. 94
Old Jan 29, 2013 | 08:50 AM
SlvrJdm's Avatar
Honda civic 98 sedan
SlvrJdm's Avatar
Lx
Old Jan 29, 2013 | 12:05 PM
fcm's Avatar
fcm
Old Fart
http://www.bulldogsecurity.com/diagr...13580&MakeID=3
No you do not need the remote start relay satellite.
You should not need anything on the "Auxiliary Wiring Harness Connector".
You need the blue and green leads of the "Power Doorlock Interface Port" for keyless entry if you have power door locks.
On the "Secondary Wiring Harness Connector" you do NOT need..
"Light Relay (programmable) wires, unless you want to do your headlights.
Violet, + door trigger.
Red/white, unless you have a power trunk/hatch release.
White/black, - park light output.
"“Horn” Relay (programmable), unless you want to wire the horn.
On the "Main Power & Output Connector" the pink/white "Programmable Relay Output" will need to be programed as ACC. and connected to the cars white/black [2nd ACC.].
Best bet is to remove, [depin] the unused leads, to get them out of the way. 9494
Old Jan 29, 2013 | 08:50 PM
SlvrJdm's Avatar
[IMG] [/IMG]
Old Jan 29, 2013 | 08:56 PM
SlvrJdm's Avatar
i have some question it on the image hope you can answer. Im sorry to upload it very late been busy with school all day. Hope you can help fcm : ) greatly appericated on your wiring information. Can't wait to put it in as soon when you done checking the image. Hopefully the information you give me is all i need and not no more wiring. If you can verify that would be great. Thank you once again!!!
