need help fast have searched
Old Oct 2, 2006 | 07:57 AM
dcsports's Avatar
Default need help fast have searched
i need to install a pionner deck in my 1995 civic ex i have read post with some charts wire it that way and still does not work my harness was cut when previous owner had it plz help 4 weeks with no radio sucks i have 2 head one is a deh-p7500mp and the other is a deh-p7400mp plz help =\
Old Oct 2, 2006 | 08:04 AM
B18C_EJ8's Avatar
Maybe it's not working because you don't capitalize or use proper punctuation?
http://www.installdr.com/Harnesses/HA-Wiring.pdf
What specifically doesn't work when you wire according to the chart?
Old Oct 2, 2006 | 08:39 AM
dcsports's Avatar
Default Re: (B18C_EJ8)
pmd but for others to read it does not power up
Old Oct 2, 2006 | 08:42 AM
B18C_EJ8's Avatar
Have you checked the fuses in both fuse boxes? And by "checked", I mean verified with a meter, not just pulled out and looked at??
Old Oct 2, 2006 | 08:47 AM
dcsports's Avatar
i have checked the fuse on the radio and under the dash i should only be looking for those 2 fuses right? and wat kind of meter is that i need
Old Oct 2, 2006 | 08:58 AM
B18C_EJ8's Avatar
You need a volt/ohm meter, preferably one that will test for continuity.
Old Oct 2, 2006 | 12:42 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: (dcsports)
Did you check the fuse under the hood nex to the battery, the 7.5 amp fuse? Since the harness was cut it would of blown that fuse.
Old Oct 2, 2006 | 10:04 PM
dcsports's Avatar
Default Re: (wrx-killer-Sti eater)
i have one wire thats not connected it its a red with black stripe where does that connect to
Old Oct 3, 2006 | 05:52 AM
B18C_EJ8's Avatar
Get your wiring color codes at http://www.installdr.com
umair
Nov 13, 2008 07:54 PM
uspeedwalt
Audio / Security / Video
Sep 23, 2007 01:44 PM
lazyweasal4
Dec 12, 2006 04:06 PM
NickTJohnson
Jul 15, 2006 05:50 PM
CoolKat
Mar 22, 2003 03:26 PM
