Custom RCA Cables?
Old Oct 2, 2006 | 07:52 AM
AlienKrOZ's Avatar
Default Custom RCA Cables?
Can i make a custom RCA cable? what size gauge wire should I need? What kind of connectors also? any how-to's on this??
Old Oct 2, 2006 | 08:07 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">What kind of connectors also?</TD></TR></TABLE>
I'm no professional, but I think you would use RCA connectors???
Just buy good cables... It's going to be cheaper and sound better; unless you have the proper equipment to properly terminate the cables.
Old Oct 2, 2006 | 08:20 AM
AlienKrOZ's Avatar
Default Re: (B18C_EJ8)
tahnks alot
Old Oct 2, 2006 | 08:54 AM
fcm's Avatar
fcm
Old Fart
Default Re: Custom RCA Cables? (AlienKrOZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Just buy good cables... It's going to be cheaper and sound better; unless you have the proper equipment to properly terminate the cables.</TD></TR></TABLE> I have to agree, unless you have made interconnect cables before your better off just buying what you need.
Although it is possible to "make" a RCA cable with nothing more then a soldering gun and a set of side cutters, [there are even some "solder-less" RCA terminals out there, not recommended] to do them properly you really need
1- A solder pot... http://www.action-electronics....Plato
2- A proper "stripping tool" something like this... http://www.partsexpress.com/pe...2-688
3- A soldering station, [or pencil]... http://www.radioshack.com/prod...earch
4- A terminal and wire holder of some kind. 94
Old Oct 2, 2006 | 10:29 AM
rcurley55's Avatar
New User
I'd disagree with you guys - you can make your own RCA's at a FRACTION of the cost if you have patience and soldering skills.
Take a look at canare star quad mic cables for a great, low cost cable for your rcas. Mix it with any of your favorite solder rca connectors and you are good to go.
Takes a lot of time to build, but you can tailor them to match your install and cut them to custom lengths.
Far and away cheaper then what is available commercially at this level of quality.
Old Oct 2, 2006 | 10:50 AM
B18C_EJ8's Avatar
No one is saying that he can't do it... We're just suggesting that he not do it if he lacks the proper tools...
Old Oct 2, 2006 | 11:15 AM
rcurley55's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">No one is saying that he can't do it... We're just suggesting that he not do it if he lacks the proper tools...</TD></TR></TABLE>
fair enough, I read your post too quickly - unless you can solder - mid-fi commercially available cable should be fine...
Old Oct 3, 2006 | 08:01 AM
nsxxtreme's Avatar
Default Re: (rcurley55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcurley55 &raquo;</TD></TR><TR><TD CLASS="quote">I'd disagree with you guys - you can make your own RCA's at a FRACTION of the cost if you have patience and soldering skills.
Far and away cheaper then what is available commercially at this level of quality.</TD></TR></TABLE>
I would have to agree you dont need any special tools. A soldering iron and some wire strippers/ cutters is all you need.
It doesn't take a rocket scientist to solder some wire. You might want to practice on junk wire first. Only use rosin core flux and use at least 99% alcohol to clean the flux. The cheap crap they sell at the local drug store is 70% and will not do anything.
AlienKrOZ
Audio / Security / Video
Apr 30, 2007 03:35 PM
Rahxephon
Honda Civic (2006 - 2015)
31
Dec 19, 2006 08:08 PM
huge230
Welding / Fabrication
Feb 17, 2006 09:05 PM
noob with an RS
Nov 19, 2004 06:35 AM
speedracer33
28
Jul 23, 2003 06:28 PM
