Need Help with Amp Install on 97 TEG
I'm trying to get the power cable through the firewall, but I can't find a hole to pull it through. Could someone tell where a hole would be or if i have to drill one?
[Modified by Marc-OS, 11:32 PM 12/5/2001]
Don't quote me on this, but I believe there is a enough space to push it thru where the wiring harness passes thru. At least that's the case with civics.
There are two places I normally run the wire though-
Behind the battery there is a rubber grommet. Make a hole in that and feed the wire though. It'll come out around the passenger foot area.
The other place is by the driver's side of the intake manifold, there's also a grommet there doing nothing. The wire should come out around the console area.
ummm...i think another easy way is to just run the wire through your fender, dont quote me though im not sure, but thats how my friends in a del sol and sentra did theirs.
civichatch67
Mar 23, 2005 01:46 PM
Flamenco-T
Audio / Security / Video
Jul 18, 2001 09:59 PM
