Need help with Alpine CDA-9815
Old Dec 14, 2003 | 12:05 AM
X-Static's Avatar
Default Need help with Alpine CDA-9815
i hooked up my 9815 yesterday and im gettin too much bass and not enough treble in my mids, but ive noticed theres no simple bass or treble adjustments. So im wonderin how the F i can fix it. Ive messed with the x-over, and eq but its not helpin..but then again i dont truelly understand how it works..
So i guess my question is, How do i turn down the bass and up the treble on the mids/highs?
Old Dec 14, 2003 | 12:39 PM
hellas's Avatar
Default Re: Need help with Alpine CDA-9815 (X-Static)
you can turn the defeat on, which will bypass all its fancy features. hit the volume **** till you see defeat, then turn the ****. you can also turn down the sub volume with the same method
to get rid of bass go to the eq screen, select a frequency around 60 hertz (band, search buttons), then lower it by turning the volume ****. if you want to raise hights, select a freq above 4khz and turn the volume **** up.
make sure the xover isnt cutting all the highs. set everything at 100hz
Old Dec 18, 2003 | 01:45 PM
KRiS1's Avatar
It is a seriously confusing unit but sounds great when you get it figured out.
jeremyrocksursox
Apr 3, 2009 06:30 AM
CaptWalt
Honda Civic (2006 - 2015)
20
Mar 24, 2009 09:22 AM
EM2_08
Audio / Security / Video
Feb 8, 2009 09:21 PM
Swanny0213
Dec 20, 2006 02:12 PM
