Need Help
Old Aug 23, 2006 | 09:30 PM
funny_718's Avatar
Default Need Help
96 Integra at spl 3 door alright this is my setup
1.Pioneer CD Deck
1.Front Speakers are Alpine 6-1/2" 2-Way Component Car Speakers with Hybrid Fiber Cones Up to 350 watts peak power (70 watts RMS)
2.Back Speakers are Alpine 6-1/2" 2-Way Coaxial Car Speakers with Hybrid Fiber Cones Up to 250 watts peak power (50 watts RMS)
3.And my amp is a Multi-Channel Car Amp Infinity Reference Series 164W Class AB 4-Channel MOSFET Amplifier 164W peak output @ 2 ohms 111W RMS x 4 @ 4 ohms 139W RMS x 4 @ 2 ohms 278W RMS x 2 @ 4 ohms
these ar the two problems i have one is when the volume is of at zero or like at 8 u hear a noise like sssssssssssssss. And the other is when i driving and i give the car gas u hear another weird nosie and with that nosie i dont care at what level u have the volume u hear it wat can be cuasing this?
plz help thank you
Old Aug 23, 2006 | 09:59 PM
bpr0422's Avatar
Default Re: Need Help (funny_718)
grounds....
wire placement: power/ground too close signal wires..
excessive gain??
Old Aug 24, 2006 | 11:15 AM
funny_718's Avatar
thanks dude so the power and the ground are too close together thanks for the help
Old Aug 24, 2006 | 12:02 PM
technine's Avatar
Default Re: (funny_718)
Try running RCA's on one side and power ground and remote wire on the other side of the car. I have had no problem with any system I did once I did this, but when I put the RCA's on the side with the power wire I get the "rpm noise" you are gettting.
Also, make sure you ground to a good spot maybe shock tower bolt or something if it's in the trunk and make sure to scrape/sand paint away so you get a bare metal surface, makes a big difference usually.
Old Aug 24, 2006 | 03:22 PM
fcm's Avatar
fcm
Old Fart
You have 2 noise problems the "sssssssssssssss" is probably system noise, gains on amp too high, the other is alternator whine and can be caused by a number of things or a combination of things.
The first thing I would check is the amps ground, where and how is it grounded, how long is the ground lead?
Power for amp should be run down the batt. side of car.
RCAs should be kept away from the power cable or any power wires as much as possible, run them down center of car.
Again, another Pioneer HU with noise problems when connected to a diff. brand amp. 94
Old Aug 24, 2006 | 10:01 PM
bpr0422's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by funny_718 &raquo;</TD></TR><TR><TD CLASS="quote">thanks dude so the power and the ground are too close together thanks for the help</TD></TR></TABLE>
i said the power OR ground is too close to the SIGNAL wire
please read a little more slowly... for ur own good :-)
Old Aug 24, 2006 | 10:04 PM
bpr0422's Avatar
Default Re: Need Help (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> You have 2 noise problems the "sssssssssssssss" is probably system noise, gains on amp too high, the other is alternator whine and can be caused by a number of things or a combination of things.
Again, another Pioneer HU with noise problems when connected to a diff. brand amp. 94</TD></TR></TABLE>
I found it way too much work to run stuff down the center hump.. also there isn't much room there... so power is down the driverside.. and rcas/speakers down the pass...
why not the other way around?? fuel pump wire is on the driverside.. so are alot of other wires... but their all lower voltage come to think of it
Popoy
Audio / Security / Video
May 26, 2009 07:28 AM
BLUE EH3
Feb 4, 2006 03:03 AM
aboh6leenz
Dec 9, 2004 08:43 PM
h2392si
Oct 24, 2003 09:54 PM
noi_nho401
Apr 14, 2003 12:29 AM
